Hi I just got the EVGA NU Audio and installed it.
It has some issues in Playback - it stutters now and then when I tried to play back the Witcher 3 FLAC Audio files.
(tried 32 Bit, 191200, 352800, 384000khz)
I am not sure if there is a correlation to "CPU" Demand - like starting an App or anything alike.
Also It seems that I have to do a restart now and then to get it working again after some time (energy saving?).
Second, Using it in BF V I get strong distortions on the sounds - 384000khz
Are there any hints what to check or known Bugs in the driver?
DXDiag also shows a "Error: resolving further soundinformation results in an error" on start up.
DX Diag Shows the following in case it helps:
Sound Devices
Description: Lautsprecher (2- EVGA NU Audio)
Default Sound Playback: Yes
Default Voice Playback: No
Hardware ID: TUSBAUDIO_ENUM\VID_3842&PID_3100&KS
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: EVGA_NU_AUDIO_no_limitks.sys
Driver Version: 4.55.0000.0000 (English)
Driver Attributes: Final Retail
WHQL Logo'd: n/a
Date and Size: 06.12.2018 00:00:00, 53288 bytes
Other Files:
Driver Provider: EVGA
HW Accel Level: Basic
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: SPDIF Interface (2- EVGA NU Audio)
Default Sound Playback: No
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
HW Memory: 0
Description: Digitalaudio (S/PDIF) (High Definition Audio-Gerät)
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0900&SUBSYS_1043864B&REV_1000
Manufacturer ID: 1
Product ID: 65535
Type: WDM
Driver Name: HdAudio.sys
Driver Version: 10.00.17763.0001 (English)
WHQL Logo'd: Yes
Date and Size: 14.09.2018 00:00:00, 398336 bytes
Other Files:
Driver Provider: Microsoft
Cap Flags: 0xF1F
HW Memory: 0
Description: ROG PG348Q (NVIDIA High Definition Audio)
Hardware ID: HDAUDIO\FUNC_01&VEN_10DE&DEV_0091&SUBSYS_38422487&REV_1001
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: nvhda64v.sys
Driver Version: 1.03.0038.0004 (English)
WHQL Logo'd: Yes
Date and Size: 22.10.2018 00:00:00, 227896 bytes
Other Files:
Driver Provider: NVIDIA Corporation
Cap Flags: 0xF1F
HW Memory: 0
Sound Capture Devices
Description: Line (2- EVGA NU Audio)
Default Sound Capture: Yes
Default Voice Capture: Yes
Date and Size: 12/6/2018 13:56:09, 53288 bytes
Cap Flags: 0x1
Format Flags: 0xFFFFF
Description: Mikrofon (2- USB Camera-B4.04.27.1)
Default Sound Capture: No
Default Voice Capture: No
Driver Name: USBAUDIO.sys
Date and Size: 9/15/2018 08:28:15, 191488 bytes
Cap Flags: 0x1
Description: Microphone (2- EVGA NU Audio)
Cap Flags: 0x1
post edited by DarkTrooper - 2019/01/24 12:33:56
