EVGA Gtx 770 - Question on 6-pin and 8-pin PCI-e connectors
maxondm
2014/03/18 09:25:37 (permalink)
Hi !
I have a question about powering my GTX 770 card which has:
1. 6 pin connector
2. 8 pin connector.
I checked my 650 watt PSU, its some unknown brand and lists 19 amp on both 12 volt rails.
My question is :
Will i be able to run this thing on this PSU - EVGA recommends 42A in total on 12 v rails .
I also figured out that my PSU has only 1 PCI-e 6 pin connector whereas got numerous molex pin connectors.
How can i connect the 8 pin connector when there's only one 6 pin connector even i use the adapter.
The packaging has 2 adapters for 6 and 8 pin connector.
I would really appreciate if someone can help me with nearly same hardware setup .
Thanks!
My Hardware
Intel core-i7 4770k
MSI G45-Z87 Gaming
AData 2133 MHz 2X8GB
Western Digital 2x2TB Green
EVGA GTX 770 2GB SC
HAF X Gaming Case
Generic 650 watt PSU (from old PC) - 19V each on 12volt rails
14 Replies Related Threads
    • Ribbons : 86
    Re: EVGA Gtx 770 - Question on 6-pin and 8-pin PCI-e connectors 2014/03/18 10:51:48 (permalink)
    I have always been scared of no name PSUs. I have seen far too many of these provide poor output, unsteady output, or just turn into smoke under high load. I really have to recommend a good PSU and my first choice for you is Corsair. EVGA makes good PSUs as well.
    Maestro Sartori
    Re: EVGA Gtx 770 - Question on 6-pin and 8-pin PCI-e connectors 2014/03/18 10:52:06 (permalink)
    Well from the looks of it your going to have to get a new psu...especially with the recommendation for amps and you only having one 6 pin pcie connector. And what the previous poster said also...
    I use pc power and cooling psu's, I just put in a new 850 watt with my gtx 760 sc and everything is working great.
    https://shop.pcpower.com/...Mk_III_850W/index.html
    The screw in modular cables are nice also but have to warn you, the cables are set up to mount the psu at the bottom of the case. If you mount it at the top and route the power sata cables down the plugs are upside down.
    post edited by Maestro Sartori - 2014/03/18 11:03:56
    maxondm
    Re: EVGA Gtx 770 - Question on 6-pin and 8-pin PCI-e connectors 2014/03/18 11:26:28 (permalink)
    Can i use 8 pin to 2 molex pin adapter since i dont have 8 pin pcie connector on my psu.
    My Hardware
    Intel core-i7 4770k
    MSI G45-Z87 Gaming
    EVGA GTX 770 2GB SC
    HAF X Gaming Case
    maxondm
    Re: EVGA Gtx 770 - Question on 6-pin and 8-pin PCI-e connectors 2014/03/18 11:31:57 (permalink)
    Or will this Thermaltake PSU work:
    http://www.thermaltake.com/products-model.aspx?id=C_00001776
    Thanks!
    post edited by maxondm - 2014/03/18 11:34:16
    My Hardware
    Intel core-i7 4770k
    MSI G45-Z87 Gaming
    EVGA GTX 770 2GB SC
    HAF X Gaming Case
    NemesisChild
    Re: EVGA Gtx 770 - Question on 6-pin and 8-pin PCI-e connectors 2014/03/18 12:11:47 (permalink)
    The 770 requires a minimum of 42 amps on the +12v rail.
    That Thermaltake PSU has two +12v rails, but each rail falls short of 42 amps.
    So, you would have to use both +12v rails to power your 770.
    You would then have to reference the wiring diagram to determine which PCI-e cable is on which +12v rail.
    With that being said, I would recommend a PSU with a single +12v rail like this:
    http://www.newegg.com/Pro...x?Item=N82E16817139012
    post edited by NemesisChild - 2014/03/18 12:14:15
    Intel i9 10850K@ 5.3GHz
    Corsair H115i Pro XT
    ASUS ROG Strix Z490-E
    G.Skill TridentZ@ 3600MHz 32GB CL14
    EVGA RTX 3090 Ti FTW3 Ultra
    OS: WD Black SN850 1TB NVMe M.2
    Storage: WD Blue SN550 2TB NVMe M.2
    EVGA SuperNova 1200 P2
    ASUS ROG Strix Helios GX601
    maxondm
    Re: EVGA Gtx 770 - Question on 6-pin and 8-pin PCI-e connectors 2014/03/18 13:39:21 (permalink)
    Can you provide me a list of PSU best suitable for EVGA GTX 770 2GB SC ?
    I prefer Corsair , Seasonic or NZXT with price tag of $100.
    Thanks in advance!
    My Hardware
    Intel core-i7 4770k
    MSI G45-Z87 Gaming
    EVGA GTX 770 2GB SC
    HAF X Gaming Case
    bob16314
    • Ribbons : 761
    Re: EVGA Gtx 770 - Question on 6-pin and 8-pin PCI-e connectors 2014/03/18 13:46:58 (permalink)
    The recommended 600W 42A 12V is the minimum recommended total system power requirement based on an average/mid-range PC configured with an Intel Core i7 3.2GHz processor, not just for the GTX 770 itself.
    The GTX 770 card power draw is rated at 250W which is 21A @ 12V, of which 75W (6.25A @ 12V) can be supplied by the PCIe slot itself..An additional 75W (6.25A @ 12V) can be supplied by the 6-pin PCIe supplemental power connector and 150W (12.5A @ 12V) from the 8-pin PCIe supplemental power connector as long as the PSU is up to the task..The card could draw up to a combined 14.75A from the PCIe supplemental power connectors, and 6.25A from the PCIe slot which equals the 21A rating of the card.
    Your generic PSU might get by using that adapter, but probably not, or probably not for long, I certainly wouldn't go for it..That Thermaltake unit should work fine with 30A on +12V1 and 22A on +12V2..There are better units..Corsair makes pretty good units, as well as EVGA like rjohnson11 said..I like single +12V rail units, but that's just personal preference, there's nothing wrong with multi-rail units.
    Use this PSU calculator to get a fair idea of your total system wattage requirement.
    Long story short = Get a good PSU.
    • Ribbons : 86
    Re: EVGA Gtx 770 - Question on 6-pin and 8-pin PCI-e connectors 2014/03/18 14:12:06 (permalink)
    A 600 watt PSU with a 12 volt line of 42 amps is recommended. I searched on Newegg and if you MUST stay at 100 bucks then this would be fine:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139060
    However if you are willing to go a little over your budget I recommend this Corsair model:
    http://www.newegg.com/Pro...x?Item=N82E16817139061
    Might be cheaper here: http://www.ncixus.com/pro...91783&promoid=1230
    This will give you a bit more wattage leeway.
    maxondm
    Re: EVGA Gtx 770 - Question on 6-pin and 8-pin PCI-e connectors 2014/03/18 14:57:25 (permalink)
    I would order SeaSonic G-750 SSR-750RM in a weeks time. The eXtreme Power Supply Calculator Lite recommends me to get 501 watt minimum.
    Until then can you help me with this Thermaltake Litepower 700W W0356 PSU setup:
    There's one 6 pin and one 8 pin connector on the PSU for a straight forward connection . Should i worry about the two 12V rails and/or is there anything else to configure?
    My Hardware
    Intel core-i7 4770k
    MSI G45-Z87 Gaming
    EVGA GTX 770 2GB SC
    HAF X Gaming Case
    bob16314
    • Ribbons : 761
    Re: EVGA Gtx 770 - Question on 6-pin and 8-pin PCI-e connectors 2014/03/18 15:11:22 (permalink)
    maxondm
    Nope.
    maxondm
    Re: EVGA Gtx 770 - Question on 6-pin and 8-pin PCI-e connectors 2014/03/18 15:53:35 (permalink)
    Thanks guys for all your support !
    I will update this thread once i install the Thermaltake PSU tomorrow. I may need further help with switching off inbuilt gpu(HD 4600) or setup Lucid Virtu etc, i am absolute noob to these stuffs.
    My Hardware
    Intel core-i7 4770k
    MSI G45-Z87 Gaming
    EVGA GTX 770 2GB SC
    HAF X Gaming Case
    stealthp90
    Re: EVGA Gtx 770 - Question on 6-pin and 8-pin PCI-e connectors 2014/03/18 16:06:24 (permalink)
    I am just going to put this bluntly, if you try to run that card on a no-name PSU rated at 19 AMP's on the 12 volt rail you are asking for your entire computer to fry. 19 ams can only provide slightly more then 200 watts of power and that card will some times draw way more then that. And when you over tax a ****ty PSU they have an amazing tendency to fry everything that is connected to them. JUST DONT DO IT!!!!!!!!!!!!
    MOBO: Asus Crosshair VI Hero
    CPU: AMD Ryzen 7 1700
    GPU1: EVGA GTX 1080 FTW DT ACX 3.0
    GPU2: EVGA GTX 1080 FTW ACX 3.0
    RAM: 16 Gb @ 3200 Mhz G.Skill Flair X CL14
    PSU: Corsair RM850I
    SSD1: Samsung 960 EVO 256 GB
    SSD2: Samsung 850 PRO 256 GB
    SSD3: Samsung 850 EVO 250 GB
    HDD1: Western Digital Caviar Green 3 Tb 5400 rpm
    Tweaked
    • Ribbons : 29
    Re: EVGA Gtx 770 - Question on 6-pin and 8-pin PCI-e connectors 2014/03/18 19:39:03 (permalink)
    bob16314
    Excellent explanation of how the PSU works to provide power to our cards.  Thank you.
    EVGA DG-77/ EVGA 750 G2/ Gigabyte B450/ AMD Ryzen 5 3600/ 16gb Crucial Ballistix DDR4-3600/ RTX-2080 XC/ Dell S2716DG / Windows 11 64
    maxondm
    Re: EVGA Gtx 770 - Question on 6-pin and 8-pin PCI-e connectors 2014/03/22 01:02:18 (permalink)
    The thermaltake PSU with 48 amps on the 12 V rails installed just fine with a included two 6+2 pin connectors.
    I am testing this card at the moment by running various benchmarks and configuring it for After effects and 3dsmax.
    Would like to thank everybody who helped me during this process.
    Thank you!
    My Hardware
    Intel core-i7 4770k
    MSI G45-Z87 Gaming
    EVGA GTX 770 2GB SC
    HAF X Gaming Case
