Re: EVGA FTW 3090 FTW3 Ultra 3rd fan noise normal?
Tuesday, November 22, 2022 3:28 AM
Yeah, the 3rd fan is the blue header.
Problem is that there is a problem with the PWM signal which causes the weird harmonic sound, so it's a lottery whether you find a fan which doesn't play up with the weird signal.
