Re: EVGA 3080ti Hybrid Fan Control Question
Saturday, May 14, 2022 6:07 PM
Strange no response..
Anyways no idea how px1 shows 2 fans as usually you only see the cards fans and the rad fans you can't control unless something has changed??
Card is recognized correctly it seems by px1.
Anyways try just linking the fans together and then manually adjusting to see what fans respond.
Nor.ally one would need to unplug the fans from the rad and install them to an external fan controller or on the motherboard and control them from there.
I usually just set the rad fans to a static % like whatever you can handle.. say 75-80 or 100%.
Control the gpu fan with the fan curve on px1.
Asus Z390 ROG Extreme XI MB
