ENERMAX Introduces REVOLUTION D.F. X ATX 3.0 Power Supply Series
  • Ribbons : 86
2023/07/01 01:00:28 (permalink)
https://www.techpowerup.com/310714/enermax-introduces-revolution-d-f-x-atx-3-0-power-supply-series
ENERMAX, an industry-leading force dedicated to designing extreme performance computer power supplies and cooling solutions, launches its latest Intel ATX 3.0 and PCIe 5.0 ready power supply series -the REVOLUTION D.F. X, from 850 W to 1600 W, featuring one native 600 W 12VHPWR cable, an extra 600 W 12VHPWR adapter cable for multiple GPUs usage, ARGB side panel and ENERMAX's patented Dust-free Rotation technology for self-cleaning function to make sure your systems run stable and stylish for years.
The REVOLUTION D.F. X power supply series is 80 Plus Gold certified and compliant with Intel ATX 3.0 and PCIe 5.0 standards in a compact 140 mm chassis in depth. To meet the demands of ultra-efficiency computing performance, REVOLUTION D.F. X is characterized by industrial-grade 100% Japanese capacitors, advanced LLC and Synchronous Rectifier (SR) design to deliver outstanding performance and unparalleled flexibility for PC enthusiasts and professionals.
The ENERMAX's patented Dust-free Rotation technology enables the fan inside to blow away dust upon powering on, keeps the power supply remains clean, prevents any future disruption and ensures a stable power delivery for years.
Moreover, the fan is designed with ENERMAX semi-fanless technology, it allows the fan to be completely off until the load exceeds 20% to create 0 dB(A) environment and ensures a quiet operation during minimum load. The fan is designed with a 6-pole, 3-phase motor and pressure blades to deliver extremely high air pressure and high airflow while maintaining outstanding quietness.
The REVOLUTION D.F. X series also comes with an ARGB side panel with built-in 14 RGB lighting modes. It allows gamers to light up their REVOLUTION D.F. X without additional software installation required. The RGB control button next to the power switch allows customers to turn it off at night with one push. Customers can also sync the lighting effects of REVOLUTION D.F. X via the supported motherboard's software.
The REVOLUTION D.F. X 850 W, 1050 W and 1200 W are now available from ENERMAX's worldwide authorized retailers and distributors; the 1350 W and 1600 W will be released in late Q3 this year. ENERMAX offers up to 10 years warranty for the REVOLUTION D.F. X series; the warranty term may be different by region.
The 10 year warranty is highly noteworthy.
2 Replies Related Threads
    Flybye
    Re: ENERMAX Introduces REVOLUTION D.F. X ATX 3.0 Power Supply Series 2023/07/02 05:22:59 (permalink)
    I have an Enermax Galaxy 1000w that did great for almost 15 years. If these are just as good, I'll say whatever they are asking for it is well worth it.
    Gaming thing
    i9-12900KF @ 5.20GHz
    EVGA: Z690 Classified - RTX 3080 FTW3 Ultra - Supernova 1200w P3 - DG-75
    32GBs Corsair Dominator DDR5 @ 6800 - Seagate: .5TB, 1TB M.2s, HD 4TB
    Sony CRT 24" GDM-FW900 16:10 - DangerDen (RIP) Goodies: 2x120mm Rad & D5 + Primochill stuff
    Hoggle
    Re: ENERMAX Introduces REVOLUTION D.F. X ATX 3.0 Power Supply Series 2023/07/02 08:39:53 (permalink)
    The RGB is kind of cool if you have the PSU fan face the inside of the case. Most gamer cases though would face the fan towards the bottom. That means the RGB would be upside down and facing the side of the case.l that likely doesn’t have a window.
