Cooler Master to Release MasterCase H500P ATX Chassis on October 10th for $149
  • Ribbons : 86
2017/10/04 23:40:13 (permalink)
https://www.techpowerup.com/237587/cooler-master-to-release-mastercase-h500p-atx-chassis-on-october-10th-for-usd-149
This is the successor to Cooler Master's HAF. Available for pre-order from Newegg for $149
11 Replies Related Threads
    Hoggle
    Re: Cooler Master to Release MasterCase H500P ATX Chassis on October 10th for $149 2017/10/05 01:58:44 (permalink)
    Case looks really good and probably we will see a lot of builds using it.
    Bobmitch
    • Ribbons : 49
    Re: Cooler Master to Release MasterCase H500P ATX Chassis on October 10th for $149 2017/10/05 06:38:29 (permalink)
    Since I still use optical drives...not going to be a good one for me...too bad...like the design
    MSI MAG X670-E Tomahawk;  Ryzen 7 7800X3D; Asus TUF RTX 4070 TI OC; Seasonic Vertex GX-1000 PSU; 32 GB  Corsair Vengeance DDR5-6000 CL30 RGB; Corsair iCue Link H150i LCD 360MM AIO; 2-Western Digital Black 4 TB SN850X NVMe; Creative SoundBlaster Z;  Lian Li Lancool III; Corsair K70 RGB Pro MX Speed Silver Keyboard; Razer Viper 8K Mouse
    Heatware:  https://www.heatware.com/u/72402
    Affiliate code: 1L2RV0BNQ6
    Associate Code:  UD82LJP3Y1FIQPR
    • Ribbons : 86
    Re: Cooler Master to Release MasterCase H500P ATX Chassis on October 10th for $149 2017/10/05 07:07:20 (permalink)
    bobmitch
    What type of case are you looking for Bob? I have the 780T from Corsair as it supports optical drives.
    • Ribbons : 115
    Re: Cooler Master to Release MasterCase H500P ATX Chassis on October 10th for $149 2017/10/06 21:32:39 (permalink)
    Love the case.
                My Affiliate Code: 8WEQVXMCJL
     &nbsp
    Syzich
    Re: Cooler Master to Release MasterCase H500P ATX Chassis on October 10th for $149 2017/10/07 04:53:25 (permalink)
    I really like Cooler Master cases. I plan on using this and the Storm Stryker/Trooper in upcoming builds. ( ' - ')b
    kougar
    • Ribbons : 22
    Re: Cooler Master to Release MasterCase H500P ATX Chassis on October 10th for $149 2017/10/09 16:27:46 (permalink)
    Really not a fan of glass panels. Though I suppose it's still an improvement over the cheap plastic ones held in place with even cheaper plastic rivets that the old CM HAF cases use. Gah. Going to hold onto my HAF-X anyway, but will probably go Corsair sometime in the future.
    Have water, will cool.
    Bobmitch
    • Ribbons : 49
    Re: Cooler Master to Release MasterCase H500P ATX Chassis on October 10th for $149 2017/10/09 21:42:06 (permalink)
    bobmitch
    Took a look at that one on your recommendation.  Something to consider....Thanks
    • Ribbons : 86
    Re: Cooler Master to Release MasterCase H500P ATX Chassis on October 10th for $149 2017/10/09 22:21:47 (permalink)
    bobmitch
    bobmitch
    Hoggle
    Re: Cooler Master to Release MasterCase H500P ATX Chassis on October 10th for $149 2017/10/09 23:55:57 (permalink)
    bobmitch
    bobmitch
    Looked at the case on Amazon and it has pretty good reviews. Oddly if you get it with a case fan the price drops $18 vs. just buying the case alone. Not sure why but $158 is a reasonable price for a full tower case and spare 120mm fan.
    jd63636
    Re: Cooler Master to Release MasterCase H500P ATX Chassis on October 10th for $149 2017/10/25 07:27:43 (permalink)
    I did a build on this case last week and despite what some of the reviewers said and IMO the case is sturdier than reviewers led us to believe. Who knows but maybe the review samples were preproduction units.
     I see no issues with fit of the panels and overall fit and finish of the case. The front panel clips securely into place and I had no problem picking the case up and moving it from the office to the living room with the front and top panels on. The top panel could clip on a touch more securely but is it not a deal breaker by any means.
    The tempered glass panel on my case fits very securely. I do have a 1/16 – 1/32 gap top to bottom between the window and the case. I had both 3/8 by 1/8 and ¼ by 1/16 single sided closed cell foam tape in the garage and used the 1 / 4 by 1/16  on the front and rear edge for a perfect seal.
    Cable management in the rear is excellent and the covers provided are awesome for concealing your bundles of cable and keeps everything very neat behind the side panel.
    There has been quite a bit of discussion regarding the case and airflow but my results are quite good. My temps as reported by HW monitor while playing WoW and after running Time Spy, Fire Strike and  Unigine Superposition stress tests never exceeded 60c CPU and 64c GPU. I added a pair of the Cooler Master 200mm fans up top and now see 55c CPU 60c GPU temps so all and all I am quite pleased with the cooling and really like the aggressive industrial look of this case.
    My build:
    Asus Maximus iX Hero
    Core i7 6700K
    16GB Corsair Vengeance DDR4 3200 LPX
    Noctua NH-D15
    EVGA GTX 1070 FTW2
    EVGA SuperNova 750 G3
    post edited by jd63636 - 2017/10/25 09:07:10
    Fractal Meshify 2 - 3  Lightwings 140mm  front intake & 1 Lightwings 140mm rear exhaust - Ryzen 5900x - X570S MSI Tommahawk Max WiFi -Bequiet Pure Loop 2 FX 360mm - 32GB Hyper X Fury DDR4 3600 - Sabrent 1TB Rocket 4.0 PCIe 4.0 M.2 NVMe - 1TB Adata SX8200 Pro M.2 NVMe -XFX Merc 319 RX 6750XT - Corsair RM1000x (2021 edition) - Dell S3422DWG- Glorious GMMK2 with lubed Alpaca Linear Switches and Glorious GPBT Celestial(ICE) Keycaps- Glorious Model D Wireless
    Syzich
    Re: Cooler Master to Release MasterCase H500P ATX Chassis on October 10th for $149 2017/10/25 11:57:47 (permalink)
    The agressive look is exactly why I like Cooler Master cases. I like the panels Cooler Master uses. A lot of other cases I see are pretty much just metal boxes with little to no style. I see other people comment in various places such as PCPartPicker that they're sick of the RGB craze and flashiness, but I really like it. My current build is in a Cooler Master Storm Sniper. Nice build, btw. I like seeing other black/blue builds. (  ' -')b
    post edited by Syzich - 2017/10/25 12:00:31
