Hot!Cooler Master Brings 57-inch Dual 4K Mini LED Gaming Monitor to Computex 2024
  • Ribbons : 86
2024/06/05 23:12:51 (permalink)
https://www.techpowerup.com/323288/cooler-master-brings-57-inch-dual-4k-mini-led-gaming-monitor-to-computex-2024
This might be the gaming monitor some of you have been waiting for, as Cooler Master has pulled out all the stops with its GP57ZS monitor that the company was showing at Computex. Apart from being a massive 57-inches, the monitor offers dual 4K resolution, or 7680 x 2160 pixels, which are lit up by a 2304-zone Mini LED backlight. We've seen similar displays from both Samsung and Acer. Cooler Master is clearly using the same VA panel as the previously mentioned companies and you also get the same 1000R curvature here, which means the GP57ZS isn't going to be for everyone. Cooler Master didn't provide any refresh rate details, nor the types of inputs that will be on offer.
In addition to this, Cooler Master also showed off a pair of new 27-inch models, both sporting a 2560 x 1440 resolution. The cheaper GM27QP gets a 1500R curved 160 Hz VA panel and HDR400 support, as well as a DP 1.4 and two HDMI 2.0 inputs. It also gets to make do with basic Adaptive Sync VRR, but it does have gaming features like crosshair, an FPS counter and black stabilisation. The more premium GP27QP on the other hand gets a flat display panel of unknown type with a 240 Hz refresh rate, which is illuminated by an 1152 zone Mini LED backlight. Typical brightness is 350 nits and the contrast ratio is 2500:1, but the display is also HDR1000 certified. Connectivity is seriously upgraded here with two DP 1.4 and two HDMI 2.1 inputs, as well as a USB Type-C input that also delivers 96 Watts of USB PD power. In addition to this, there's also a USB Type-B input and three USB Type-A outputs. For some reason it seems like Cooler Master has stuck with Adaptive Sync on this model too, but this model does at least gain support for Picture-in-Picture and Picture-by-Picture support.
Now that is one big monitor
0 Replies Related Threads
