Re: Case suggestions for all AIO layout
2016/03/04 08:36:10
Dschijn
quick fix... make the AIO fans all as intake from outside!
Unfortunately I've been unable to find a way to do so. Currently I have the two Hybrid rads in the front in pull config with two 140mm fans (FD GP-14) pushing from the front and the Nepton exhausting out the rear. As a result when the GPUs spool up they're dumping their heat into the case which elevates CPU temps. The R5 has filters on the bottom and front only.
Regards,
Falc
"If everyone could just stop and close their eyes for a moment, imagine how quiet and serene it would be until the looting started"
