Can EVGA Precision XOC (and 1080 Ti FTW3) increase case fan speed based on GPU load?
sofakng
2017/05/22 19:11:21 (permalink)
Can EVGA Precision XOC increase case fan speed when GPU load increases?
If not, can anybody recommend any software?  (preferably very minimal/lightweight software)
2 Replies Related Threads
    scott@bjorn3d
    Re: Can EVGA Precision XOC (and 1080 Ti FTW3) increase case fan speed based on GPU load? 2017/05/23 03:55:09 (permalink)
    Well it is not moving it as per say under load.  What happens as temps climbs the fans speed up to keep it cool.  Running Folding @ Home with a 1080TI FE sitting under my FTW3 the FTW3 is still running low 60's on GPU and Memory, the power is running around 67C.
    That is with my FTW3 and the 1080TI FE both Folding at 100%
    redleader00
    • Ribbons : 7
    Re: Can EVGA Precision XOC (and 1080 Ti FTW3) increase case fan speed based on GPU load? 2017/05/23 05:11:51 (permalink)
    sofakng
    The only program I know is SpeedFan. I do not use it myself, so you will have to give it a try and see what can be done or not.
    post edited by redleader00 - 2017/05/23 05:14:41
