Calyos NSG S0 Fanless Chassis With Phase Change Cooling
  • Ribbons : 271
2017/03/30 11:22:26 (permalink)
The production chassis is designed by France's modding duo WaterMod, which improved upon the original open-frame concept design both in terms of performance and aesthetics. The usage of Phase Change cooling through two cooling blocks - one for the GPU, another for the CPU) makes away with fans, pumps, water, and any other assorted cooling techniques that involve calling upon the decibel gods.
Sources:
https://www.techpowerup.com/231975/kickstarted-calyos-nsg-s0-fanless-chassis-with-phase-change-cooling
https://www.kickstarter.com/projects/1489140137/nsg-s0-worlds-first-fanless-chassis-for-high-perfo/description#
I think it is a really good idea.  I am surprised at how well it performs when connected to a pretty powerful computer.  My only concern with the product displayed is that it doesn't have a low-speed fan blowing over the GPU and motherboard to keep the passive components cool.
post edited by ty_ger07 - 2017/03/30 13:42:50
6 Replies Related Threads
    panzlock
    Re: Calyos NSG S0 Fanless Chassis With Phase Change Cooling 2017/03/30 11:44:38 (permalink)
    It's like the shift from supercars and muscle cars to electric cars. I'll stick with fans and noise.
    WackyWRZ
    • Ribbons : 7
    Re: Calyos NSG S0 Fanless Chassis With Phase Change Cooling 2017/03/30 13:23:53 (permalink)
    "Fanless" huh??? Interesting that it comes with 5 cup holders then!
    I do think it looks really cool though!  With an industrial radiator look.
    CASE: Anidees AI Crystal XL | MOBO: ASUS X470 Crosshair VII | CPU: AMD Ryzen 3600 | RAM: G.Skill Trident Z DDR4-3200 2x8GB B-Die | SSD: Samsung 970 EVO Plus NVME 1TB | PSU: EVGA SuperNOVA 650 P2 | GPU: AMD RX5700 XT | MON: AOC CU34G2X 1440p/144hz 34" Ultrawide + Dell S2716DG 1440p/144Hz | Cooling: Full custom loop, Heatkiller D5 150, Aquacomputer D5 Next + Quadro, EK Supremacy Evo, EK Coolstream PE 480, Bykski 5700XT | HEAT: 20-0-0 - http://www.heatware.com/u/104452
    • Ribbons : 271
    Re: Calyos NSG S0 Fanless Chassis With Phase Change Cooling 2017/03/30 13:31:38 (permalink)
    WackyWRZ
    Yes, interesting choice, huh?  It is fanless, though.  It doesn't come with fans and they have tested it many hours without fans and found that it performed better than the stock air coolers which came with the components they tested.  Third parties have also duplicated those results.  Linus tested a prototype for 3 days straight.  Watch his video, if you wish.
    If you look through their pictures, you will see that those areas are where you mount your hard drive(s), solid state drive(s), or other accessories.
    I think they purposely haven't included fans and haven't advertised the option to add fans, but I think it is clear that they do give you the option to add fans (if you wish).
    Check out the information and videos posted on their Kickstarter for more details.
    An older prototype which is supposed to be inferior to the current design:
    https://www.youtube.com/watch?v=9PJOrfpiVwE
    post edited by ty_ger07 - 2017/03/30 13:47:44
    lehpron
    Regular Guy
    • Ribbons : 191
    Re: Calyos NSG S0 Fanless Chassis With Phase Change Cooling 2017/03/30 17:38:05 (permalink)
    It's a nice idea, I'd get on board. But many may not realize that vapor phase change is the process by which all traditional heatpipe technology works, and nothing to do with the popular concept of refrigerator compressor subzero cooling when people talk about "phase change".
    This idea is ultimately just a flexible heatpipe application. If the fin array and transfer process were large enough to support a Peltier (TEC) module, then silent subzero is possible-- a topic I know quite a bit about-- the potential of this Kickstarter idea isn't lost on me...
    post edited by lehpron - 2017/03/30 17:40:15
    For Intel processors, 0.122 x TDP = Continuous Amps at 12v [source].
    Introduction to Thermoelectric Cooling
    somethingc00l
    EGC Admin
    • Ribbons : 11
    Re: Calyos NSG S0 Fanless Chassis With Phase Change Cooling 2017/03/31 17:27:06 (permalink)
    Hardly a new concept.
    E.g: https://www.quietpc.com/tnn500af
    Looks like a good implementation, though not sure it's worth $700.
    • Ribbons : 115
    Re: Calyos NSG S0 Fanless Chassis With Phase Change Cooling 2017/04/03 20:52:35 (permalink)
    I think it's pretty neat. Looks good to me.
                My Affiliate Code: 8WEQVXMCJL
     &nbsp
