Cablemod unveils 90 degree angle 12VHPWR power adapter for GeForce RTX 40 GPUs
  • Ribbons : 86
2022/10/17 03:59:42 (permalink)
https://videocardz.com/newz/cablemod-unveils-90-degree-angle-12vhpwr-power-adapter-for-geforce-rtx-40-gpus
Cablemod have announced the highly anticipated 90-degree angle power cable adapter for the modern GeForce GPUs. This cable supports the full 600W spec, and it solves the most basic problem with RTX 4090 GPUs, which is insufficient clearance for power cables.
As we know, there are many RTX 4090 cards that are far wider than RTX 30 series. Not only the thickness and length are important, but the card’s width as well. To make matters worse, NVIDIA’s power adapter, which is added to every RTX 4090 card sold by board partners, needs a few centimeters of clearance on its own. As a result, many new RTX 4090 owners were forced to use their cards without side panels until a solution was found.
The 90-degree cable only requires an additional 23.2 mm of space to be properly installed. The connector itself will be available in two configurations, ensuring that it fits all RTX 4090 and most likely RTX 4080 series as well.
Unfortunately, the cable is not yet on sale. The company announced that pre-sale will start on October 31st, and can sign up to be notified as soon as it starts.
It's a brilliant idea from cablemod.
9 Replies Related Threads
    cezarL
    Re: Cablemod unveils 90 degree angle 12VHPWR power adapter for GeForce RTX 40 GPUs 2022/10/17 04:25:54 (permalink)
    Thanks.
    A welcome solution for FE cards, but, by the looks of it, not usable on AIB cards which have the power connector recessed into the frame :(
    playboyer
    Re: Cablemod unveils 90 degree angle 12VHPWR power adapter for GeForce RTX 40 GPUs 2022/10/17 09:05:30 (permalink)
    How did they even release such a cable design in the first place knowing many wouldn't be able to install their side panels. It's like they designed the card to fit in a deep freezer. I was surprised I couldn't install the side panel on my Lian Li 011 Dynamic XL with the Gigabyte RTX 4090 Gaming OC installed!
    the_Scarlet_one
    formerly Scarlet-tech
    • Ribbons : 79
    Re: Cablemod unveils 90 degree angle 12VHPWR power adapter for GeForce RTX 40 GPUs 2022/10/17 11:00:30 (permalink)
    cezarL
    Thanks.
    “The connector itself will be available in two configurations, ensuring that it fits all RTX 4090 and most likely RTX 4080 series as well.” From the article.
    Hopefully it will work.
    B0baganoosh
    • Ribbons : 42
    Re: Cablemod unveils 90 degree angle 12VHPWR power adapter for GeForce RTX 40 GPUs 2022/10/17 11:17:17 (permalink)
    the_Scarlet_one
    cezarL
    Thanks.
    Ah yes, I hadn't noticed at first that it can angle up or down depending on which configuration you get.
    6Q6CPFHPBPCU691 is a discount code anyone can use.
    i9 13900k - EVGA Z690 Classy - Nvidia RTX 4090 FE - G.Skill 64GB DDR5-6000CL30  - WD SN850 2TB NVMe Gen4 - Be Quiet! Straight Power 12 1200W - Be Quiet! Dark Base 900 Pro. MO-RA3 420 Pro. Dark Palimpsest MODS RIGS post for build notes.
    cezarL
    Re: Cablemod unveils 90 degree angle 12VHPWR power adapter for GeForce RTX 40 GPUs 2022/10/17 11:28:42 (permalink)
    Angling up wouldn't be of much use to those of us sporting air coolers like the NH-D15 :/
    I'm not worried as I have a Torrent case which has plenty of room to fit the power adapter without needing a connector (and besides I might not even get a 4090) but it'd still be nice to see a flexible/rotating connector coming out...
    Mystikalrush
    • Ribbons : 9
    Re: Cablemod unveils 90 degree angle 12VHPWR power adapter for GeForce RTX 40 GPUs 2022/10/18 15:23:29 (permalink)
    HELLO EVGA?! Would someone PLEASE say something, where is your cable for YOUR EVGA PSUs?!
    | Intel i9 12900K @5.2GHz | NZXT Kraken X73 | Corsair 4000D | Gigabyte AORUS PRO Z690 | EVGA SuperNova 1000 G6 |
    | RTX 3090FE @2.1GHz | 980 PRO 2TB | 980 PRO 1 TB x 2 | G.Skill Trident Z5 RGB 32GB 6000MHz | LG 34" UW 1440p 144Hz |
    TheOnlyDoor
    Re: Cablemod unveils 90 degree angle 12VHPWR power adapter for GeForce RTX 40 GPUs 2022/10/27 12:29:12 (permalink)
    I have the same exact card in the same exact case. Had to slightly bend the adapter to fit but it worked.
    Wish I could post pictures here.
    • Ribbons : 271
    Re: Cablemod unveils 90 degree angle 12VHPWR power adapter for GeForce RTX 40 GPUs 2022/10/27 14:40:22 (permalink)
    Mystikalrush
    EVGATech_LeeM
    Which is probably why it's a good thing we're working on a cable that can work with 40 Series....
    yaymz
    Re: Cablemod unveils 90 degree angle 12VHPWR power adapter for GeForce RTX 40 GPUs 2022/10/27 15:00:59 (permalink)
    playboyer
    Did you consider a vertical GPU mount/riser?  I'm about to put together an O11DXL with 4090 in about a month, but with a vertically mounted GPU..
    cpu: Intel 12900k-EK Quantum Magnitude waterblock
    mobo: Asus z690 Apex
    ram: G.skill DDR5 @ 6000+.
    gpu: MSI 4090 Suprim Liq x on EK-Quantum Vector² Trio ABP waterblock
    ssd: Samsung m.2 980 Pro 2TB (x2)
    psu: beQuiet Dark Power Pro 1500w
    case: Lian-li o11d xl
    monitor: Asus ROG Swift 27" 1440p @240hz (PG279QM).[/
