CPU to PSU cable not working/supplied with wrong cable
Matthew.stockings
2018/11/10 14:36:55 (permalink)
I ordered and built my EVGA 650w GQ power supply. I have built and checked everything in my pc and everything turns on/works except when I use the cable labeled 'CPU'. I can tell it's not meant to fit with my motherboard (ROG Strictly B360-G Gaming), I'm guessing they're not compatible because when I force it in (not too hard that anything is breaking) and turn the pc on everything turns on for less than a second then turns off. However, the YouTuber who I got my build off made it work perfectly with the same parts, however he unfortunately time lapsed the build.My friend recommended me to get an adapter which I have purchased
I was wondering if this would work given that my motherboard has 8 pins and this one has 4, I searched it up and there's mixed reviews, some people say it works fine, others say it will slow your pc down, others say this is dangerous. I was wondering if you guys could recommend what I should do, thank you for your time.
10 Replies Related Threads
    Matthew.stockings
    Re: CPU to PSU cable not working/supplied with wrong cable 2018/11/10 14:39:30 (permalink)
    https://www.amazon.co.uk/gp/aw/d/B01FWIKB26 that is the adapter, for some reason the link didn't work the first time I pasted it
    • Ribbons : 282
    Re: CPU to PSU cable not working/supplied with wrong cable 2018/11/10 14:40:22 (permalink)
    Remember that one end is for the MB the other is the PSU
    You Need No Adapter..........DO NOT USE ONE
    Your CPU EPS connector is 2 4-Pin Connectors put together to create an 8-Pin EPS Connector.
    post edited by bcavnaugh - 2018/11/10 14:55:20
    Matthew.stockings
    Re: CPU to PSU cable not working/supplied with wrong cable 2018/11/10 14:42:12 (permalink)
    The ends are different, one only fits for the PSU and the other doesn't work for the MB
    • Ribbons : 282
    Re: CPU to PSU cable not working/supplied with wrong cable 2018/11/10 14:44:14 (permalink)
    Second cable down on the left side is the correct cable you need. Your PSU comes with 2 EPS CPU Cables.
    Put the two 4-Pin connector together with the Clip or Lock on the same side next to each other and plug into your 8-Pin EPS CPU Connector on your Motherboard.
    post edited by bcavnaugh - 2018/11/10 14:56:41
    Matthew.stockings
    Re: CPU to PSU cable not working/supplied with wrong cable 2018/11/10 14:48:30 (permalink)
    The split ends go into my mb, single one goes to PSU and pc turns on and off, when the cable for CPU is unplugged everything turns on, is this a different problem from a different part I've fitted wrong?
    • Ribbons : 282
    Re: CPU to PSU cable not working/supplied with wrong cable 2018/11/10 14:51:59 (permalink)
    Matthew.stockings
    Maybe, need more info.
    Your 24-Pin Cable is plugged in I take it.
    Do not use any cable that has VGA on it and use on the EPC CPU connector.
    Make sure you also plugging in the EPS CPU Cable in the CPU 1 or CPU 2 on your PSU.
    "pc turns on and off" Check that you have no Motherboard Standoffs Sorting your MB.
    The Hole count should be the same as the number on the MB Tray in your Computer Case. I count 8 Standoffs are used.
    Remove you MB from the Case and retest. MAKE Sure you have a Cooler Installed on the CPU.
    post edited by bcavnaugh - 2018/11/10 14:58:50
    Matthew.stockings
    Re: CPU to PSU cable not working/supplied with wrong cable 2018/11/10 14:55:42 (permalink)
    I haven't used any vga cables, 24pin is in and I'm plugging eps into CPU 1 and I tried 2 with the same result
    • Ribbons : 282
    Re: CPU to PSU cable not working/supplied with wrong cable 2018/11/10 14:59:44 (permalink)
    Time to bench test and count them Standoffs.
    Matthew.stockings
    Re: CPU to PSU cable not working/supplied with wrong cable 2018/11/10 15:00:05 (permalink)
    Stand offs are off, I'm tired atm and am going to go to sleep, thank you for your help and time I really appreciate it, I'll touch up on this in the morning
    • Ribbons : 282
    Re: CPU to PSU cable not working/supplied with wrong cable 2018/11/10 15:45:11 (permalink)
    You are Very Welcome.
    Keep us posted
