CORSAIR Launches LX RGB Fans, a Union of Brilliant Lighting and Exceptional Cooling
  • Ribbons : 86
2024/06/18 23:53:09 (permalink)
https://www.techpowerup.com/323699/corsair-launches-lx-rgb-fans-a-union-of-brilliant-lighting-and-exceptional-cooling
Corsair today launched the LX RGB Series of cooling fans, the latest addition to the acclaimed iCUE LINK ecosystem. Proving that amazing lighting and high-performance cooling are not mutually exclusive, the LX RGB Series redefines the expectations of PC enthusiasts - and thanks to iCUE LINK, makes building and connecting your masterpiece easy and convenient.
Available in 120 mm and 140 mm sizes, in your choice of black or white to match the aesthetic of your build, each LX RGB fan features 18 individually addressable RGB LEDs spread across an inner and outer light loop, creating spectacular, fully customizable lighting effects - including the iCUE LINK-exclusive Time Warp mode that creates mesmerizing optical illusions. All of this is made possible by the new and improved iCUE 5 software, making it easier than ever before to customize and switch between lighting effects or synchronize them with your games.
These great looks are backed up by rigorous engineering and meticulous testing to deliver strong, efficient cooling to match. A combination of high airflow, reaching PWM-controlled speeds up to 2,400 RPM, and high static pressure make LX RGB fans well suited for use as case fans or attached to radiators. Corsair AirGuide Technology, with its anti-vortex vanes, also focus airflow direction to move air more efficiently through your case.
Moreover, the LX RGB Series is designed for quiet operation, with Magnetic Dome bearings minimizing friction to ensure low noise and superior longevity. Zero RPM Mode completely eliminates fan noise at low loads, with the fans spinning up only when your system demands it.
Installation is made effortless with Corsair's innovative one-twist QuikTurn screws, empowering you to install a full set of fans in seconds, saving both time and effort. iCUE LINK bridge connectors included with the fans let you stack them directly together to create a seamless bank of fans with no intervening wires, making installation even easier.
With the LX RGB Series, Corsair continues to push the boundaries of PC cooling and aesthetics with a powerful one-two punch of brilliant lighting and exceptional cooling.
Availability
The LX RGB Series is available now in multi-fan Starter Kits with an iCUE LINK System Hub or single fan Expansion Kits from the Corsair webstore and the Corsair worldwide network of authorized retailers and distributors.
The LX RGB Series is backed by a five-year warranty, alongside the Corsair worldwide customer service and technical support network.
These iCue Link fans look very good.
0 Replies Related Threads
