COLORFUL Announces iGame GeForce RTX 4080 16GB Advanced and Ultra W Graphics Cards
  • Ribbons : 86
Wednesday, November 09, 2022 6:24 AM (permalink)
https://www.techpowerup.com/300871/colorful-announces-igame-geforce-rtx-4080-16gb-advanced-and-ultra-w-graphics-cards
olorful Technology Company Limited, a professional manufacturer of graphics cards, motherboards, all-in-one gaming and multimedia solutions, and high-performance storage, announces the iGame GeForce RTX 4080 16 GB Advanced OC and iGame GeForce RTX 4080 16 GB Ultra W OC graphics cards - the latest addition to the GeForce RTX 40 Series.
The new iGame GeForce RTX 4080 Advanced OC and Ultra White models feature a new look while retaining all the signature features from each series. The Ultra White retails its all-white shroud that aims to complement white-themed gaming PC builds. On the other hand, the iGame GeForce RTX 4080 16 GB Advanced OC features the new Gravity Rim—a redesigned version of the iGame Energy Core from the previous generation models that provides a new look and lighting ambiance.
iGame GeForce RTX 4080 16 GB Advanced OC-V
The new COLORFUL iGame GeForce RTX 4080 16 GB Advanced OC also gets face lift with its simpler and stealthier design while improving the iGame Energy Core of the previous-generation thus introducing the new Gravity Rim central fan design. The two other fans of the graphics card uses the new Hurricane Scythe Blade design, as seen on the earlier released iGame GeForce RTX 4090 Vulcan OC-V graphics card. It also features the Hollow Back Design with an iGame grille for aesthetics.
Key Features
  • Gravity Rim: A redesigned version of the iGame Energy Core that creates a mysterious black hole effect.
  • Meteorite Backplate: A sturdy metal backplate that reduces PCB flexing. An intricate iGame grille design is added to the backplate's hollow back to add aesthetics.
  • Hurricane Scythe Blades: New fan blade design that delivers superior airflow compared to the previous-generation Storm Chaser fan design. The Advanced OC uses two 100 mm fans and a 96 mm center fan.
  • One-Key Overclock: A conveniently placed button located at the rear I/O that activates overclocking function for a quick and easy performance boost without opening software.
  • Hollow Back Panel: A hollow back panel design that allows airflow to freely pass-through the heatsink. This design greatly improves heat dissipation compared to conventional GPU air cooling designs.
  • Customizable RGB Lighting: COLORFUL is all about adding a touch of colors to your gaming PC. The graphics card features RGB lighting that is fully customizable using the iGame Center software.
iGame GeForce RTX 4080 16 GB Ultra W OC-V
The new iGame GeForce RTX 4080 16 GB Ultra W sports a new look and a more powerful triple-fan cooler design while adopting the 12VHPWR connector standard. The new design features the new Retro RGB side panel with the ULTRA branding. The RGB lighting is fully customizable using the iGame Center software.
Key Features
  • ULTRA Retro RGB: Eye-catching and visualizing RGB lighting effect in a retro design.
  • ULTRA Cooling: The Ultra Series are designed with high-performance cooling in mind - featuring a large heatsink with five 5 mmØ + two 8 mmØ copper heat pipes fitted with three 100 mm cooling fans.
Pricing
  • iGame GeForce RTX 4080 16 GB Advanced OC-V: $1289
  • iGame GeForce RTX 4080 16 GB Ultra W OC-V: $1249
Personally I find the prices too high.
0 Replies Related Threads
