Bitspower Unveils Classic-series Water Block for Galax RTX 3090 EX Gamer
  • Ribbons : 86
2021/03/26 02:28:14 (permalink)
Bitspower Unveils Classic-series Water Block for Galax RTX 3090 EX Gamer | TechPowerUp
Bitspower today unveiled a Classic series full-coverage water block for the Galax/KFA2 GeForce RTX 3090 EX Gamer graphics card (model: BP-VG3090GXEXG). This card features a slight variation of the NVIDIA reference-design board for the GA102, and is found in a number of custom-design cards by Galax, KFA2, and other AIC partners that source from Galaxy Tech. The Bitspower Classic water-block for this card uses nickel-plated copper as its primary material, pulling heat from the GPU, VRM, and memory chips on the obverse side of the PCB. An aluminium back-plate is included along with thermal-pads, to pull heat form the memory chips on the reverse side. It features clear acrylic top. This top is studded by addressable-RGB LEDs that take input from a standard 3-pin ARGB header. The block supports standard G 1/4" fittings. It measures 264 mm x 138 mm x 28 mm (LxHxW). Available now, it is priced at USD $250.
This is a great looking block but 250 bucks seems a bit high in price in my opinion.
0 Replies Related Threads
