Bitspower Releases Socket AM5 Compatibility Kit for its Water Blocks
  • Ribbons : 86
Friday, September 16, 2022 11:10 AM (permalink)
https://www.techpowerup.com/298946/bitspower-releases-socket-am5-compatibility-kit-for-its-water-blocks
Bitspower, one of the world's leading suppliers of water-cooling equipment for performance computers, today launched the Bitspower AM5 kit which can transform AMD-based Bitspower CPU water blocks into an AM5-compatible product. More and more setups used by gamers, streamers, and creators will harness AMD's new AM5 platform, which provides native support for up to 170 W—meaning there's power to do more, play more, and create more than ever before. However, with this increased power comes higher temperatures.
Fortunately, AMD has ensured that existing AM4 cooling solutions can be supported with their newest motherboards, with the product's height and port distance being managed in a 7 mm increment. With the new AM5 kit, Bitspower's current range of AMD CPU blocks can directly migrate to AM5 socket motherboards. The company's latest generation CPU water blocks, such as the M Pro Water Blocks, are optimized for cooling Ryzen 7000-series CPUs, allowing users to take that already-powerful processor to new heights.
M5 motherboards have an integrated CPU socket backplate with #UNC 6-32 threads, which requires a new mounting system. This CPU-socket backplate is best kept untouched since removing it also means tinkering with the CPU loading mechanism and exposing the socket pins. Bitspower's AM5 kit is a set of screws that are integrated into the water block and screwed into the stock backplate of the motherboard. Additionally, the kit works with all-in-one units and tower fans.
I'm glad to see the kits available long before the Zen 4 CPU release.
0 Replies Related Threads
