TechPowerUp - Arctic Announces P12 PWM PST A-RGB 0dB White Fan
“ARCTIC is launching the P12 PWM PST A-RGB 0 dB white case fan today. In light of the continuing demand for white cooling products, the cooling specialist is adding this semi-passive 120 mm fan with digitally addressable LEDs and impressive performance and appearance to its range.
As the additional "0 dB" shows, the P12 PWM PST A-RGB stops automatically via PWM at low CPU load. This allows for silent operation when idle and at the same time guarantees maximum performance when needed - for example for gaming, video editing or running graphics software. At maximum operation, the fan reaches 2000 rpm, but remains pleasantly quiet at 0.3 sone even at full speed thanks to the hydrodynamic bearing and its rubberized, vibration-reducing contact surfaces.
Y-splitters on the fan and A-RGB connectors make retrofitting additional fans very easy. Like all ARCTIC P-series fans, the P12 PWM PST A-RGB 0 dB is optimized for high static pressure, and the warranty period is six years. The P12 PWM PST A-RGB 0 dB White is also now available in a pack of three.
The P12 PWM PST A-RGB 0dB White is now available in the ARCTIC webshop and in stores starting at a price of € 15,99 MSRP.
For more information, visit the
product page.”
My thoughts: Decent looking fans for the price if you want white fans. For what it’s worth, here is a review done by Igor’s Lab:
Igor’s Lab.de.
