Antec Announces Fusion 120 ARGB Case Fans
  • Ribbons : 86
2022/09/02 05:17:27 (permalink)
https://www.techpowerup.com/298494/antec-announces-fusion-120-argb-case-fans
Antec Inc., a leading provider of high-performance computer components and accessories for the gaming, PC upgrade and Do-It-Yourself market, presents a new efficient case fan with addressable ARGB called Fusion. The case fan is available in black or white and features a dodecagonal lighting with 16 LEDs for mesmerizing visual effects, hydraulic bearings for quiet operation and an innovative flow acceleration channel for better airflow. The Fusion 120 ARGB fan is now commercially available from 17,99€ (suggested retail price including VAT).
Fusion measures 120 mm x 120 mm x 25 mm and operates at a speed of 600 - 2000 RPM. Hydraulic bearings ensure a low fan noise and excellent cooling performance, all at a lifespan of approximately 40.000 hours. The Fusion fan delivers a maximum airflow of 57,93 CFM and reaches a maximum air pressure of 2.11 mm H₂O.
The new Antec fan is made of a sturdy dodecagonal plastic frame and features eight anti-vibration pads to keep the noise down even when the system is running high. Coupled with PWM control, the fan speed can be kept at a minimum when under light loads, essentially allowing for quiet yet powerful functionality. The overall effect allows the Antec Fusion fans to maintain a cool airflow over the heat-sensitive components in your PC. Fusion's cables are covered in woven wire for extra longevity and premium aesthetics.
The fan comes in packets of one, three or five fans and is covered with a 2-Year-Warranty.
The 2 year warranty is not bad provided the price is good.
0 Replies Related Threads
