Amazon Basics CPU Air Cooler for LGA1700 and AM5 Pictured
  • Ribbons : 86
2023/04/04 00:00:53 (permalink)
https://www.techpowerup.com/306796/amazon-basics-cpu-air-cooler-for-lga1700-and-am5-pictured
There is now an Amazon Basics CPU air cooler that works with Intel Socket LGA1700 and AMD Socket AM5. Called simply the CPU Air Cooler (model: RR-H410-20PC-AS), it features a conventional aluminium fin-stack tower-type design, and uses four copper heatpipes that make direct contact with the CPU at the base. A 92 mm fan ventilates the cooler. This fan is RGB illuminated and includes a controller. The fan turns at speeds ranging between 600 to 2,000 RPM, pushing up to 34.73 CFM of airflow, and features a conventional rifle bearing.
The cooler itself measures 102 mm x 83.4 mm x 136 mm (WxDxH), and Amazon Basics claims that it can handle thermal loads of up to 200 W. Amazon Basics usually brings otherwise obscure white-box brands into the market under its marquee so customers with confidence in the Amazon brand can buy them. In this case, the retail giant roped in no less than Cooler Master as the OEM for this cooler. The cooler itself appears to be a rebadged version of the Hyper H410R RGB, but with updated retention modules to support the latest CPU socket types. Amazon Basics is pricing this at $28.47. You can catch a review at the source link.
Well the price is very reasonable.
1 Reply Related Threads
    Hoggle
    Re: Amazon Basics CPU Air Cooler for LGA1700 and AM5 Pictured 2023/04/04 02:50:54 (permalink)
    It's a reasonable price and should handle most models well since if you are going with an i9 or are overclocking you probably have already figured into the budget more than this $28.49 cooler. The Toms Hardware review wasn't as bad on the product as I would have expected for the price on this item.
    Core i9-13900K Thermal Results - Amazon Basics CPU Cooler Review: Quiet Air Cooling for Mainstream Rigs | Tom's Hardware (tomshardware.com)
