Air Flow through the FTW 3080 Cooler. Is there a specification?
kevinc313
  • Ribbons : 22
Re: Air Flow through the FTW 3080 Cooler. Is there a specification? 2020/10/15 18:53:50 (permalink)
njbongo
Use this link, you need it
https://www.nimh.nih.gov/.../find-help/index.shtml
Sick burn bro.  If this was my first day on the internet, my feelings would be hurt.
#31
SmookinJoe
Re: Air Flow through the FTW 3080 Cooler. Is there a specification? 2021/09/20 16:36:09 (permalink)
irakandjii
I read with great interest a discussion regarding high temperatures on a FTW 3080.  There was a lot of speculation regarding the root cause.  It turned out that the problem was mitigated by adding some fans to the case.
I would ask that EVGA provide some design data on the air flow rate required by the FTW3 cards to ensure adequate cooling.
~~~snip~~~
I was doing a DuckDuckgo search...(i'm different..lol) and was intrigued by your thread.
I personally, am trying to determine, how to get the best cooling out of a few different cases I am using. Big folding at home Team EVGA supporter... and I was wondering if you happen to have flow charts showing video card air patterns.
No where near an expert...they all left town...lol
Kidding..
Just a couple of things I can't quite get a handle on.
On a couple of enclosed mining cases the card farthest from the cpu is always hotter than the rest.
This particular position is closest to an outside wall on the backplate side and 3 inches(possibly more) away from the back of the other gpu. Air flow in the case is straight through with 3 fans on each end..Air flowing towards the mounting brackets for the gpu's
Both walls on either side of the cases is slotted for airflow. Top solid and bottom has extra vents for another psu if needed. Guess I could add a fan on the bottom to shoot air to the hotter gpu...
Currently only using 3 cards to increase distance and help with temps.
Just was wondering if you actually had any luck with your EVGA 3080 research.
I have a few 3080 FTW3 Ultra gamers, in my machines...
post edited by SmookinJoe - 2021/09/20 16:42:34
#32
SmookinJoe
Re: Air Flow through the FTW 3080 Cooler. Is there a specification? 2021/09/20 18:14:23 (permalink)
I am starting to think the 3080's don't play well with others...in the same case..lol  Just an example of the mining case. Card on far right is always hottest and the center card is a 3080..both right cards have to be run at less than 90% power or they are over 70C..
post edited by SmookinJoe - 2021/09/20 18:30:13
#33
Kasque
Flagged as Spam (5)
Re: Air Flow through the FTW 3080 Cooler. Is there a specification? 2021/09/23 07:06:25 (permalink)
LMAO good one
#34
SmookinJoe
Re: Air Flow through the FTW 3080 Cooler. Is there a specification? 2021/09/23 10:09:03 (permalink)
Kasque
LMAO good one
It was a perfectly on topic hyjack..
There is a metal top to that mining case..
Just don't see the humour...
#35
B0baganoosh
  • Ribbons : 42
Re: Air Flow through the FTW 3080 Cooler. Is there a specification? 2021/09/23 10:10:20 (permalink)
SmookinJoe
Kasque
LMAO good one
They were spamming every post for a couple hours this morning. I wouldn't take it personal as they probably didn't read any part of this thread.
6Q6CPFHPBPCU691 is a discount code anyone can use.
i9 13900k - EVGA Z690 Classy - Nvidia RTX 4090 FE - G.Skill 64GB DDR5-6000CL30  - WD SN850 2TB NVMe Gen4 - Be Quiet! Straight Power 12 1200W - Be Quiet! Dark Base 900 Pro. MO-RA3 420 Pro. Dark Palimpsest MODS RIGS post for build notes.
#36
SmookinJoe
Re: Air Flow through the FTW 3080 Cooler. Is there a specification? 2021/09/23 10:16:01 (permalink)
B0baganoosh
SmookinJoe
Kasque
LMAO good one
Ahh!
Goin for a post count ...Thank You Sir!
#37
kevinc313
  • Ribbons : 22
Re: Air Flow through the FTW 3080 Cooler. Is there a specification? 2021/09/23 10:16:53 (permalink)
SmookinJoe
B0baganoosh
SmookinJoe
Kasque
LMAO good one
Ahh!
Make sure to report all spam and abuse to the moderators.
#38
