AZZA Introduces CAST Mid-Tower ATX PC Case with Removable Outer Shell + Independent Frame
  • Ribbons : 86
Tuesday, February 02, 2021 6:10 PM (permalink)
AZZA Introduces CAST Mid-Tower ATX PC Case with Removable Outer Shell and Independent Frame | TechPowerUp
AZZA, a leading brand of computer cases and accessories, introduces the CAST ATX PC case that re-imagines the design of a traditional mid-tower. The CAST has a removable outer shell that gives full access to the interior for effortless installation. When fully built, the unique wing design can be completely extended, requiring zero tools to access the interior, or flexed for better airflow. The CAST can even be flipped to a 90-degree orientation.
The CAST design consists of an independent frame and an outer shell with two hinged panels that provides full access to the hardware for maintenance and cleaning, and an easy to latch on/off front panel. When building the system, the entire shell can be easily removed to prevent accidental damages. This also means the shell can be worked on independently for customization purposes.
Unique Wing Design for Easy Access
The unique shell features hinged top and bottom panels, creating wings that wrap around the frame to form the left side panel. In a closed position, the CAST offers a minimalistic look with a cutout window emphasizing the graphics card. When open, it provides access to the inside and also gives an open-air option for improved internal airflow, which can be further enhanced with an included AZZA Hurricane III 120 mm ARGB fan at the back, and optional cooling for 2x 240/ 3x 120 mm fans or up to a 280/360 radiator at the front.
90-Degree Orientation
Another advantage to the hinged panel is for the case to be turned 90 degrees, standing with the rear panel facing down, giving the CAST an entirely new look to display the hardware installed inside. With enough room at the rear panel and an opening on the right-side panel to run the cables, it is easy to achieve a clean setup while breaking the traditional tower position.
The MSRP of the CAST black or white is US $209.99.
Well I personally find the case to be an interesting design.
2 Replies Related Threads
    aka_STEVE_b
    EGC Admin
    • Ribbons : 69
    Re: AZZA Introduces CAST Mid-Tower ATX PC Case with Removable Outer Shell + Independent Fr Tuesday, February 02, 2021 7:13 PM (permalink)
    also very unique
    AMD RYZEN 9 5900X  12-core cpu~ ASUS ROG Crosshair VIII Dark Hero ~ EVGA RTX 3080 Ti FTW3~ G.SKILL Trident Z NEO 32GB DDR4-3600 ~ Phanteks Eclipse P400s red case ~ EVGA SuperNOVA 1000 G+ PSU ~ Intel 660p M.2 drive~ Crucial MX300 275 GB SSD ~WD 2TB SSD ~CORSAIR H115i RGB Pro XT 280mm cooler ~ CORSAIR Dark Core RGB Pro mouse ~ CORSAIR K68 Mech keyboard ~ HGST 4TB Hd.~ AOC AGON 32" monitor 1440p @ 144Hz ~ Win 10 x64
    castrator86
    Re: AZZA Introduces CAST Mid-Tower ATX PC Case with Removable Outer Shell + Independent Fr Tuesday, February 02, 2021 8:23 PM (permalink)
    Keep a can of air at the ready ALL the time.
