AZZA Announces a Luxurious Cube Case with Infinity Mirror ARGB - REGIS 902
Flint 1760
  • Ribbons : 45
2021/12/03 12:07:13 (permalink)
TechPowerUp - AZZA Announces a Luxurious Cube Case with Infinity Mirror ARGB - REGIS 902
“AZZA introduces the REGIS 902. This luxury case is uniquely designed with a cube form factor, elevated above the surface by a premium aluminium stand, and has an infinity mirror addressable RGB front panel. The exterior is complemented with black tinted tempered glass panels and two brushed aluminium mesh panels with a touch of gold trim on the edges. ATX motherboard compatible, the REGIS supports up to 336 mm long GPUs and dual 240/280 radiators.
The REGIS has 3-sided black tinted tempered glass panels, two sides for displaying the system, and the front for featuring an infinity mirror addressable RGB which uses an ultra-thin lighting module. The addressable RGB can be controlled via the case button, or synchronized with any motherboard software. At the bottom, two anodized and brushed aluminium panels with large mesh openings complete the frame of the Regis. Each panel is mounted on snap pins for tool-less removal. In addition, golden trims on 4 of the edges highlight the luxurious look of the cube.
Meticulously designed, the CNC milled 8 mm thick aluminium stand secures the REGIS in place at 45 degrees and elevates the case 175 mm off the surface (at the highest point). This unique positioning allows the REGIS to be showcased from all angles. It also gives the REGIS a reduced footprint and improves airflow with two mesh panels for air intake from the bottom of the case.
Capable of supporting full mini-ITX, mATX, ATX motherboards, and ATX PSU, the REGIS has enough clearance for 210 mm tall CPU coolers, 336 mm long graphics card, and up to 2x 240/280 radiators which can be first mounted on removable brackets outside of the case for ease of assembly. The REGIS also holds up to 2x 2.5" SSDs or 1x 2.5" SSD and 1x 3.5" HDD which can be placed in trays and mounted in multiple positions. The REGIS includes a 140 mm PWM fan pre-installed at the rear and a PWM/ARGB hub which connects up to 7 ARGB devices and powers 6 PWM fans.
For more information: azza.gg/azza/products/unlimited/regis
My thoughts:  AZZA has put out some “different” case designs in the past and this is a continuation.  It can be yours for $399.99 preorder on Amazon or Newegg.
8 Replies Related Threads
    castrator86
    Re: AZZA Announces a Luxurious Cube Case with Infinity Mirror ARGB - REGIS 902 2021/12/03 13:38:22 (permalink)
    That base does not look sturdy enough to hold a gaming rig...
    Flint 1760
    • Ribbons : 45
    Re: AZZA Announces a Luxurious Cube Case with Infinity Mirror ARGB - REGIS 902 2021/12/03 15:13:47 (permalink)
    Here is a better view of the base.  It is milled aluminum.  This case is not something I would use.
    Kingofroam
    Re: AZZA Announces a Luxurious Cube Case with Infinity Mirror ARGB - REGIS 902 2021/12/03 15:40:56 (permalink)
    I like how theyre trying to do something different, but I think its a miss for me. price point isnt doing it any favors.
    24G-P5-3998-KR 05/24/2021 3:46:31 PM PT Yes Passed
    12G-P5-3969-KR 06/03/2021 9:05:24 AM PT Yes Bought
    CASE: Phanteks Eclipse p600s COOL: NZXT Kraken x72, ftw3 hybrid kit
    CPU: Ryzen 5600x GPU: EVGA 3080ti FTW3 Hydro Copper
    PSU: Corsair RM850x MOBO: Asus Prime x470-pro
     Don't use my associate code.
    Flint 1760
    • Ribbons : 45
    Re: AZZA Announces a Luxurious Cube Case with Infinity Mirror ARGB - REGIS 902 2021/12/03 15:54:27 (permalink)
    They have a series they call "Unlimited" none of which are inexpensive https://azza.gg/azza/unlimited.
    Some examples:
    Grey_Beard
    • Ribbons : 10
    Re: AZZA Announces a Luxurious Cube Case with Infinity Mirror ARGB - REGIS 902 2021/12/03 16:32:40 (permalink)
    Sometimes different is just that, different. Would hope that these types of gimmicky designs lead to more innovations, but I feel they won’t. The engine is an interesting design, but appeals to a limited audience. The pyramid is a bit useless, as the space is limited and looks and feels like a heat chamber. The cube could be a nice Borg themed build, but it would take some serious modifications to get there.
    All in all, meh
    Flint 1760
    • Ribbons : 45
    Re: AZZA Announces a Luxurious Cube Case with Infinity Mirror ARGB - REGIS 902 2021/12/03 17:16:01 (permalink)
    Since I always build with custom loops for my wife and I, that is how I look at cases, aesthetics comes after function.  With what I build for my wife, I have to compromise though.
    Grey_Beard
    • Ribbons : 10
    Re: AZZA Announces a Luxurious Cube Case with Infinity Mirror ARGB - REGIS 902 2021/12/03 17:54:32 (permalink)
    Flint 1760
    Same here. Currently in the process of testing a number of new (and ones I have had for a while) motherboards, CPUs, RAM and my stock of GPUs. Doing a couple of builds for our entertainment areas that are all about aesthetics. I looked at these and dabbled with building in one of them. Could never figure out how to get everything in them and not look like a disheveled mess. The engine was the only one I could have used, but could not wall mount it not would the car theme work in our areas.
    • Ribbons : 86
    Re: AZZA Announces a Luxurious Cube Case with Infinity Mirror ARGB - REGIS 902 2021/12/03 23:35:10 (permalink)
    I guess I just don't like this type of case, but maybe other modders would.
