AIO Radiator Fan Speed Question - How to set lower than 68%/1500 RPM in Precision X1?
testit13
2023/10/21 08:44:15 (permalink)
I upgraded by previous graphics card with EVGA GeForce RTX 3090 Ti FTW3 ULTRA HYBRID. Reason was to get a more quite card - my case and system use high quality fans and was quite (especially during no/little system load). Now I installed the new EVGA card and I am quite disappointed - the fan on the card seams to be quite silent but the radiator fans can not be set to lower (in precision x1 - see attached image) than 1500 RPM (or 68% fan speed). That's not acceptable for me as this is faster than other fans I have and also much more noise - any solution to this problem?.
Thanks!
 edit by Cool GTX, inserted photo
post edited by Cool GTX - 2023/10/23 10:12:59
5 Replies Related Threads
    B0baganoosh
    • Ribbons : 42
    Re: AIO Radiator Fan Speed Question - How to set lower than 68%/1500 RPM in Precision X1? 2023/10/21 09:05:16 (permalink)
    Have you tried both positions of the bios switch? There's usually a silent and an OC position, the OC position doesn't let the fans have a zero-rpm mode I don't think.
    6Q6CPFHPBPCU691 is a discount code anyone can use.
    i9 13900k - EVGA Z690 Classy - Nvidia RTX 4090 FE - G.Skill 64GB DDR5-6000CL30  - WD SN850 2TB NVMe Gen4 - Be Quiet! Straight Power 12 1200W - Be Quiet! Dark Base 900 Pro. MO-RA3 420 Pro. Dark Palimpsest MODS RIGS post for build notes.
    testit13
    Re: AIO Radiator Fan Speed Question - How to set lower than 68%/1500 RPM in Precision X1? 2023/10/22 01:30:49 (permalink)
    Thanks! - I Found the switch (was not aware of a hardware switch) - it has a normal, performance and oc mode - even in performance (not oc) you cant set it below 68% (radiator fan) - which is much too loud. With normal you can set it to lowest 22% (which is ok).
    Are there any alternative software to precision X1 for controlling the gpu (fan, oc etc.?) - maybe also software not for windows but for linux (as I mostly work under linux)?
    Thanks
    • Ribbons : 86
    Re: AIO Radiator Fan Speed Question - How to set lower than 68%/1500 RPM in Precision X1? 2023/10/22 02:04:45 (permalink)
    As far as I am aware there is no software alternative to Precision X1 in Linux.
    • Ribbons : 123
    Re: AIO Radiator Fan Speed Question - How to set lower than 68%/1500 RPM in Precision X1? 2023/10/23 10:11:23 (permalink)
    With EVGA PX1
    Place your Fans in "Auto Mode"
    make a custom fan curve & check the box for "Fan Curve Control"
    This works for my EVGA 3090Ti FTW3 Ultra Hybrid Gaming, using PX1 ver 1.3.6
    Epsolike
    • Ribbons : 17
    Re: AIO Radiator Fan Speed Question - How to set lower than 68%/1500 RPM in Precision X1? 2023/10/24 12:29:14 (permalink)
    testit13
    Thanks!
    You can replace the rad fans with any fan you prefer in existence.
    You can also just hook those fans up to a controller or your mobo, so you can adjust them as any radiator fans you would otherwise in a PC.
    EVGA X570 DARK (1.09) [manual SoC, AUTO high!]
    AMD Ryzen 5800X3D [-25 -25 -25 -20 -25 -25 -25 -25]
    GSKILL Royal Elite (Gold) 3600C14 (B-die) [F4-3600C14D-32GTEGA]
    EVGA 3080 Ti FTW3 Ultra
    EVGA SuperNOVA P6 1000
