justin_43
- Ribbons : 7
I received replacement thermal pads from EVGA for the 3090 FTW3 today and they do not include all that you need. They included the pads to cover the areas in red in this photo. They did not include pads for the green areas (I believe they are the VRMs?). It's a good thing I had a few extra to cover those as they are surely needed. I had to pay $10 for repalcements and it didn't have all that you need. Also there were no pads for the VRAM chips on the backside of the card. I can't remember if there were any to begin with, but none were included. This could all be avoided if EVGA would just go back to using thermal pads to begin with instead of the thermal putty they use now. I could have saved and reused the original pads. Not to mention that putty is horrible to remove.
ASUS RTX 4090 TUF OC • Intel Core i7 12700K • MSI Z690 Edge WiFi • 32GB G.Skill Trident Z • EVGA 1600T2 PSU 3x 2TB Samsung 980 Pros in RAID 0 • 250GB Samsung 980 Pro • 2x WD 2TB Blacks in RAID 0 • Lian-Li PC-D600WB EK Quantum Velocity • EK Quantum Vector² • EK Quantum Kinetic TBE 200 D5 • 2x Alphacool 420mm Rads LG CX 48" • 2x Wasabi Mango UHD430s 43" • HP LP3065 30" • Ducky Shine 7 Blackout • Logitech MX Master Sennheiser HD660S w/ XLR • Creative SB X-Fi Titanium HD • Drop + THX AAA 789 • DarkVoice 336SE OTL
EVGATech_DanielM
EVGA Tech Support
Re: A heads up for anyone ordering replacement thermal pads for their 30 series card
2021/11/26 11:02:30
justin_43
- Ribbons : 7
2021/11/26 11:28:06
EVGATech_DanielM You can obtain the putty from our site : https://www.evga.com/products/product.aspx?pn=M047-10-000003 We would not include pads for a area of the card that did not have it to begin with this includes under the back plate.
You are missing my point. I'm talking about the VRMs (highlighted in green in the picture) That's what I'm referring to. (I just mentioned the VRAM on the back because I wasn't sure if it had any to begin with, but I guess not) You need a thermal interface between the VRMs and the heatsink. And if I was supposed to buy putty as well why wouldn't that be mentioned by customer service? And really that putty is horrible. So to sum it up: I had to pay $10 for get only some of the pads I need. And then another $10 for putty to use on the VRMs which no one made mention of. All when you could have just used pads in the first place and save all this nonsense of having to spend money to buy replacement pads/putty. But maybe making us spend more money while saving some for EVGA during manufacturing is the point. And just to reiterate, that putty is HORRIBLE
post edited by justin_43 - 2021/11/26 11:30:11
transdogmifier
- Ribbons : 17
2021/11/26 11:31:56
I concur the putty is crap. Edit; Btw, asking us to reputty something to RMA it is also crap. That garbage disintegrates off the card when you take it apart for the hybrid kit. Either use pads that hold up to reuse to RMA or accept cards without the damn putty. Used to be that I could expect better from eVGA, but I'm beginning to see no difference between manufacturers. I'll likely buy from Asus next time
post edited by transdogmifier - 2021/11/26 11:33:42
justin_43
- Ribbons : 7
2021/11/26 11:44:23
transdogmifier Btw, asking us to reputty something to RMA it is also crap. That garbage disintegrates off the card when you take it apart for the hybrid kit. Either use pads that hold up to reuse to RMA or accept cards without the damn putty.
Exactly. My under warranty card stops working and I then have to buy pads AND putty just to send it back in. And when I tell customer service I need to replace the pads to send in the card they don't even mention the putty. Who would know I need both since the card is ONLY putty when you get it. I figured the replacement pads were for all the areas you need. I had a few pads from another brand laying around so I used those for the VRMs. I hope that won't be a problem.
EVGATech_DanielM
EVGA Tech Support
2021/11/26 11:44:57
transdogmifier I concur the putty is crap. Edit; Btw, asking us to reputty something to RMA it is also crap. That garbage disintegrates off the card when you take it apart for the hybrid kit. Either use pads that hold up to reuse to RMA or accept cards without the damn putty. Used to be that I could expect better from eVGA, but I'm beginning to see no difference between manufacturers. I'll likely buy from Asus next time
We disagree. As EVGA is one of the more tolerant in regards to warranty and disassembly of the card simply requesting you to return the item back to factory condition is not a huge ask. We encourage our customers to get the most out of their cards but if you need warranty we expect you to at least return the item in factory spec which includes all thermal pads and if the product requires it - the putty as well. As our R&D team determined that the putty is best case here this is not to avoid putting a pad in a place to cut costs. We are sorry you will decide to buy ASUS in the future but please keep in mind their terms and conditions in regards to disassembly of a GPU.
CraptacularOne
- Ribbons : 222
2021/11/26 11:49:55
justin_43 You are missing my point. I'm talking about the VRMs (highlighted in green in the picture) That's what I'm referring to. (I just mentioned the VRAM on the back because I wasn't sure if it had any to begin with, but I guess not) You need a thermal interface between the VRMs and the heatsink. And if I was supposed to buy putty as well why wouldn't that be mentioned by customer service? And really that putty is horrible. So to sum it up: I had to pay $10 for get only some of the pads I need. And then another $10 for putty to use on the VRMs which no one made mention of. All when you could have just used pads in the first place and save all this nonsense of having to spend money to buy replacement pads/putty. But maybe making us spend more money while saving some for EVGA during manufacturing is the point. And just to reiterate, that putty is HORRIBLE
I think you missed his point. Those things you circled never had thermal pads to begin with is what he's saying. The use thermal putty on them because they are just coils of copper wire in that metal box. It's virtually irrelevant what temp they get to since it doesn't matter so they use thermal putty on them. They don't actually need any cooling period. Also it was you who took the card apart was it not? If you damaged or removed what they had in place to begin with, why shouldn't you be responsible for replacing it?
- Ribbons : 270
2021/11/26 11:53:18
justin_43
You are missing his point. The stuff you highlighted in green is thermal putty. As he said, they wouldn't provide pads to replace what was thermal putty originally. If you order a thermal pad kit, you are going to get all of the thermal pads; not extra pads to replace what was never pads to begin with, and not thermal putty either. If you want thermal putty, you need to order thermal putty. Knowing what you need, and knowing the right questions to ask, is on you. You are the one who decided to take it apart.
post edited by ty_ger07 - 2021/11/26 11:57:30
justin_43
- Ribbons : 7
2021/11/26 11:55:47
Daniel I have no problem returning the card to factory spec, my problem is that when I talk to customer service and tell them I need to replace the thermal pads to send the card in they don't even mention the putty. How would I know this when the card only comes with putty to begin with? There wasn't pads on some areas and putty on others. You would think you are getting everything you need when you ask for a replacement. Should there be a replacement kit that includes both if that what you truly need?
justin_43
- Ribbons : 7
2021/11/26 11:57:51
ty_ger07 You are missing his point. The stuff you highlighted in green is thermal putty. As he said, they wouldn't provide pads to replace what was thermal putty originally. If you order a thermal pad kit, you are going to get all of the thermal pads; not extra pads to replace what was never pads to begin with, and not thermal putty either. If you want thermal putty, you need to order thermal putty. Knowing what you need, and knowing the right questions to ask, is on you. You are the one who decided to take it apart.
CraptacularOne I think you missed his point. Those things you circled never had thermal pads to begin with is what he's saying. The use thermal putty on them because they are just coils of copper wire in that metal box. It's virtually irrelevant what temp they get to since it doesn't matter so they use thermal putty on them. They don't actually need any cooling period. Also it was you who took the card apart was it not? If you damaged or removed what they had in place to begin with, why shouldn't you be responsible for replacing it?
Guys my point is that no one told me about the putty. When you get the card it ONLY has putty on all the areas. If card came with pads in some areas and putty in others I would understand. But it doesn't. I thought the pads were instead of the putty. When you ask for replacement it leads me to believe the replacement would include everything I need. If I needed to buy a second item wouldn't it make sense to tell me?
post edited by justin_43 - 2021/11/26 12:06:16
EVGATech_DanielM
EVGA Tech Support
2021/11/26 12:05:45
justin_43 Guys my point is that no one told me about the putty. When you get the card it ONLY has putty on all the areas. So when you ask for replacement it leads me to believe the replacement would include everything I need.
After review of your support ticket it does look like the representative did fail to link the putty or adequately address it but since we do not actively sell the pads on the website separate we will make sure the team in the future addresses any concern about the putty in general.
CraptacularOne
- Ribbons : 222
2021/11/26 12:06:00
I think you're just upset and want someone to yell at and I get it, I'd be mad too if my RTX 3090 died but that doesn't absolve you from your mistake. You even pointed out in your first post about thermal putty. You knew it was there, you knew you removed it. That's on you to replace it to return it to factory spec. A very small ask on their part since they also never told you to take the card apart to begin with. That was your decision, not theirs.
justin_43
- Ribbons : 7
2021/11/26 12:09:46
CraptacularOne
Dude, you aren't getting it. And really it doesn't matter if YOU do or not. I didn't make any mistake my man. When I asked for replacement pads I had no idea about replacement putty. I have no problem returning the card to factory spec. I thought the pads were INSTEAD of the putty. The card comes with zero pads from the factory. And my point wasn't to yell at anyone it was to give people A HEADS UP on the issue like my title states.
post edited by justin_43 - 2021/11/26 12:14:24
justin_43
- Ribbons : 7
2021/11/26 12:11:03
EVGATech_DanielM
Thanks Daniel. It would just be helpful to let people know they need both. I sent in the card with another brands pads over the VRMs. Is that going to be a problem?
EVGATech_DanielM
EVGA Tech Support
2021/11/26 12:13:19
justin_43 Thanks Daniel. It would just be helpful to let people know they need both. I sent in the card with another brands pads over the VRMs. Is that going to be a problem?
I will mark your RMA as a special case to let our RMA Manager Jayson aware. Should not be an issue as long as it did not physically damage it.
justin_43
- Ribbons : 7
2021/11/26 12:15:40
EVGATech_DanielM
Thanks. And no, no damage at all, just pads on the VRMs instead of putty.
CraptacularOne
- Ribbons : 222
2021/11/26 12:16:18
justin_43
CraptacularOne
So you took a $2000 card apart without any idea what you were doing? Got it The card came with thermal pads over the memory chips and MOSFETs, thermal putty on the chokes and thermal paste on the GPU die.
justin_43
- Ribbons : 7
2021/11/26 12:20:34
CraptacularOne So you took a $2000 card apart without any idea what you were doing? Got it The card came with thermal pads over the memory chips and MOSFETs, thermal putty on the chokes and thermal paste on the GPU die.
What is your problem man? You obviously just like to start stuff for no reason. And no, my card had NO PADS on it. Maybe later runs of the card came with pads. Mine did not.
CraptacularOne
- Ribbons : 222
2021/11/26 12:28:29
justin_43
I don't have a problem, it you who has the problem with accepting responsibility for your actions. And yes, your card 100% had pads on it in it's stock configuration on the MOSFETs and memory chips. They all do, yours isn't special or a one off. Ignorance isn't an excuse for innocence.
justin_43
- Ribbons : 7
2021/11/26 12:45:21
CraptacularOne
justin_43
Accepting responsibility for my actions? You are insane or just looking for a fight. I simply needed to replace the thermal interface material on the card and wasn't made aware the you needed to purchase MULTIPLE ITEMS just to send in a card for RMA. And really none of this has anything to do with you, you just wanted to insert yourself to start a fight. And quite frankly it has already been resolved. If those were pads that were on the VRAM and MOSFETs, well they sure did disintegrate just like the putty. Nothing like the pads on the countless other cards I have taken apart in the past. So whether it would be classified as putty or pads, it was not what I would call a normal thermal pad you see on past generations of cards or other parts. It sure had the consistency of putty more than a pad. But why am I telling you this? It has nothing to do with you.
post edited by justin_43 - 2021/11/26 12:47:00
CraptacularOne
- Ribbons : 222
Flagged as Spam (1)
2021/11/26 13:28:58
justin_43
CraptacularOne
justin_43
You're very upset about this aren't you? I'm not insane, you are however acting insane by throwing this big of a fit. I'm not here trying to start a fight with you, I'm here trying to educate you. You clearly misunderstood what the EVGA tech told you, then you can't tell the difference from thermal pads and thermal putty and claim your card came without thermal pads. This is factually incorrect, they all come with thermal pads over the MOSFETs and memory chips. Are you really suggesting you can't tell the difference from what is outlined in red to what I've outlined in yellow? This is the same cooler that I just snapped a pic of for you that has the thermal pads intact however the thermal putty did not survive and will need to be replaced when the stock cooler is returned to the card. If you didn't know how to properly disassemble the card, you probably shouldn't have done so to begin with.
post edited by CraptacularOne - 2021/11/26 13:30:17
justin_43
- Ribbons : 7
2021/11/26 13:49:38
CraptacularOne You're very upset about this aren't you? I'm not insane, you are however acting insane by throwing this big of a fit. I'm not here trying to start a fight with you, I'm here trying to educate you. You clearly misunderstood what the EVGA tech told you, then you can't tell the difference from thermal pads and thermal putty and claim your card came without thermal pads. This is factually incorrect, they all come with thermal pads over the MOSFETs and memory chips. Are you really suggesting you can't tell the difference from what is outlined in red to what I've outlined in yellow? This is the same cooler that I just snapped a pic of for you that has the thermal pads intact however the thermal putty did not survive and will need to be replaced when the stock cooler is returned to the card. If you didn't know how to properly disassemble the card, you probably shouldn't have done so to begin with.
No one is upset but you. This has nothing to do with you and never did. Why are you even in this thread? Why is it being continued when it's been taken care of. Whatever you want to call the stuff on the memory chips it is not a normal thermal pad. Mine was not intact when removed. Yes there is a difference, but there is even more of a difference between that and a normal thermal pad you would see on other cards. How would any of this suggest I don't know what I am doing? You just like to talk down to people. You certainly have a high opinion of yourself and feel some need to "educate" people when there is none needed, certainly not by the likes of someone with your attitude. Maybe take a step back and look at why you feel the need to act this way on an internet forum. Can a mod please lock this thread? The issue was resolved
CraptacularOne
- Ribbons : 222
2021/11/26 13:59:20
justin_43
LOL that's NOT a thermal pad?? Yeah you don't need to be disassembling any cards if you can't tell that's a thermal pad. I'm here for the same reason you posted a ill-informed "PSA". You posted this on an open discussion forum and as such we are all allowed to discuss it. You are 100% wrong, you card had thermal pads just like all the other cards do and I've shown them to you. Clearly education on your part is needed or you wouldn't posting nonsensical "PSAs"
justin_43
- Ribbons : 7
2021/11/26 14:07:21
CraptacularOne LOL that's NOT a thermal pad?? Yeah you don't need to be disassembling any cards if you can't tell that's a thermal pad. I'm here for the same reason you posted a ill-informed "PSA". You posted this on an open discussion forum and as such we are all allowed to discuss it. You are 100% wrong, you card had thermal pads just like all the other cards do and I've shown them to you. Clearly education on your part is needed or you wouldn't posting nonsensical "PSAs"
No it's not a normal thermal pad. Normal thermal pads don't fall apart like those. You are 100% percent wrong if you can't see the difference between that and what was on say a 20 series card, or 10 series or any other card from the past. And my "PSA" as you call it, still stands as the point was you need to purchase both replacement pads AND putty which was my issue from the start. I'm done with this thread. You really need to check your attitude.
CraptacularOne
- Ribbons : 222
2021/11/26 14:08:42
Wow 100% hopeless, OK I leave you to your ignorance.
justin_43
- Ribbons : 7
2021/11/26 14:09:24
CraptacularOne Wow 100% hopeless, OK I leave you to your ignorance.
I will leave you to yours. 100% arrogance. BTW no one needs your "education"
post edited by justin_43 - 2021/11/26 14:10:58
- Ribbons : 270
2021/11/26 14:27:05
justin_43 BTW no one needs your "education"
Likewise, no one needs the inaccurate "education" of this PSA you provided.
justin_43
- Ribbons : 7
2021/11/26 14:40:26
There is nothing inaccurate. I was not trying to educate anyone. It was a heads up to anyone in the same boat. All I was saying is that the replacement thermal pads don't cover all areas need to replace the cooler. When I put in for an RMA and told the rep I needed to replace the cooler I was sent a link to buy replacement thermal pads and never told I needed to make a second purchase for thermal putty. I was under the wrong impression that the replacement pads were all that I needed, and that they were instead of the putty. That you would get enough to cover all areas of the card that needed to make contact with the cooler. I made a wrong assumption. In the past this was never the case as putty was never used. This was resolved very early in this thread by Daniel from EVGA. He is the one who educated me on the subject. Now I know that you need to make 2 separate $10 purchases just to send a card in for RMA if you need to replace the cooler. I was giving a heads up to anyone else who might need to do the same.
Delirious
- Ribbons : 61
2021/11/26 16:23:13
Locked at the ops request
"Be quick to listen, slow to speak and slow to anger" Affiliate Code XZUMV9TJW5 Associate Code: 7PM43CU71IB2IAP education may be expensive but wait until you get the bill for ignorance A wise man once said that we can't make anyone feel or do anything. We can throw things into the wind, but it's up to each person to decide how they want to react, where they want to stand when things fall.
