You know, now that you mention it, I think that it may be "-AR" at the end, not -AB". It was still in the case, and I read it with a flashlight, the first time. I just looked again, and now it does look like "-AR". I checked the link that you sent, and yes, the card appears to be the same.
I do have the latest Precision installed. I was also unable to adjust the fan speed in RivaTuner, but I think that I may not have had all of the functionality, as it said that my drivers were not in its database (they are the newest NVIDIA drivers).
I just received the card, from me brother-in-law, who was using it in an SLI configuration until he bought better cards. He bought it about 2 years ago, I think. I actually have another (ATI) fan-less card, but it has this huge heatsink on the back of the card, which prevents me from putting it in PCI-e slot 1, which on this motherboard (XFX 780i) is required for non-SLI operation. That card would work fine (and quietly) in PCI-e slot 2 or 3. So, that's annoying.
I will check to see if the EVGA card has 2 or 3 wires for the fan, although in theory, a 2-wire fan can be adjusted; it just cannot be monitored (I believe that the 3rd wire is to determine the speed in RPM of the fan).
Were there any BIOS changes for this card? I could not find any. I thought that maybe a newer BIOS version might help. Video BIOS version on this card is "07/16/08".
I may just end up connecting the fan to one of the motherboard's fan connectors and adjusting the speed from there, in the motherboard's BIOS. I don't really play games on my computer, so it shouldn't get very hot. Like I said earlier, it was hovering around 46'C, which is quite cool.
post edited by parialis - Friday, December 10, 2010 0:56 PM
