6 pin to 8 pin does it work?
IITANTRUMII
2010/06/15 16:53:05 (permalink)
Hey guys  real quick silly question for the pin connectors for the gtx 480. I am running a Ultra X3 1000 watt PSU. It only has one 8 pin connector and thats for the mobo. The PSU has  four 6 pin connectors. Will a 6 pin connector to an 8 pin connector run this card? And run it safely?
BUILD LOG | 4770K @ 4.3 1.3V | WIN7 | WIN8.1 | Gigabyte UD4H EVGA GTX780SC | Corsair 16gb | 2 x Samsung EV0 250gb Raid0 2 x 128gb Crucial C300 Raid0 | Corsair AX1200 | Corsair H100 | Asus D2 | Audiotechnica ATH M50 | Bigfoot Killer 2100 | Asus 24" 144hz | HEATWARE | AFCODE:LGFVOB01VY YOUTUBE
7 Replies Related Threads
    chizow
    • Ribbons : 30
    Re:6 pin to 8 pin does it work? 2010/06/15 17:09:29 (permalink)
    The GTX 480 will include a 2x6-pin PCIe to 1x8-pin PCIe adapter, so yes if you use that then you'd be fine.  You'd use that one adapter which will use up 2x6-pin PCIe plugs, and you'd need a 3rd PCIe 6-pin to the GTX 480.
    If you went SLI you'd have to use 2x6-pin to 1x8-pin twice, leaving you no more 6-pin PCIe connectors, but the cards will also include 2xmolex to 1x6-pin PCIe adapters.  I wouldn't recommend that however, as PSUs that don't have 8-pin connectors generally aren't going to be sufficient to run newer high-draw GPUs like the GTX 480.
    Also, don't try and use the EPS 8-pin for a graphics card, its keyed differently for a reason.
    Intel Core i7 5930K @4.5GHz | Gigabyte X99 Gaming 5 | Win8.1 Pro x64 | Corsair H105
    2x Nvidia GeForce Titan X SLI | Asus ROG Swift 144Hz 3D Vision G-Sync LCD | 2xDell U2410 | 32GB Acer XPG DDR4 2800
    Samsung 850 Pro 256GB | Samsung 840EVO 4x1TB RAID 0 | Seagate 2TB SSHD
    Yamaha VSX-677 A/V Receiver | Polk Audio RM6880 7.1 | LG Super Multi Blu-Ray
    Auzen X-Fi HT HD | Logitech G710/G502/G27/G930 | Corsair Air 540 | EVGA SuperNOVA P2 1200W
    IITANTRUMII
    Re:6 pin to 8 pin does it work? 2010/06/15 17:34:35 (permalink)
    The 2x6 -pin pci to 1x8-pin is too short to connect to my card. Would the pic above work do you think?
    EVGA_JacobF
    • Ribbons : 26
    Re:6 pin to 8 pin does it work? 2010/06/15 17:48:14 (permalink)
    I would only suggest the 2x6pin to single 8pin adapter.
    mtolufson@msn.com
    Re:6 pin to 8 pin does it work? 2010/06/15 18:19:18 (permalink)
    If its too short get an extension for it, only use 2x6 to 8 as suggested before
    chizow
    • Ribbons : 30
    Re:6 pin to 8 pin does it work? 2010/06/15 18:24:24 (permalink)
    ycgerard
    I dont' see how that's possible unless the 2x6-pin are too short to connect to your card also?  If you mean they're too short to conceal all the connections than ya that's understandable, but these adapters are meant as a last resort kinda option to get what you have available working.  If you want everything to fit nice and tidy you'll have to buy a PCIe 8-pin extension cable or a new PSU.
    IITANTRUMII
    Re:6 pin to 8 pin does it work? 2010/06/16 10:51:09 (permalink)
    Thanks for all your input and help guys. Got an 8pin extender. Not really sure if the 6pin to 8pin would work but I really don't want to find out it would or not. Not sure what that would have done to my system...
    phoenixrage
    Re:6 pin to 8 pin does it work? 2010/06/16 11:55:00 (permalink)
    double check that the power supply is providing enough current on those rails.
    I have an enermax galaxy 1000W, and I have to swap it out because the 12v rails aren't able to handle the current draw for the 480's.
    i7 930
    Corsair H100
    Asus Rampage 3 Extreme
    EVGA GTX 670SC x 2
    Corsair 800D
    Corsair AX1200
    Corsair Force GT 240gb
    Intel X-25M 80GB
    2 x Corsair Force 2 120gb
    WD Blue 1TB
    WD Green 1TB
