3090 FTW3 Power draw
hassou
2021/06/11 13:13:41 (permalink)
 Hey guys,
Here I'm writing again regarding my dying GPUs with the "red light of death" 3 times,
FYI i have two 3090 FTW3s purchased on launch,
one of them works just like a charm from day one but the second was underperforming so had to RMA,
Initially i had both red lips cards so for RMA i received the revised brand new unit with Black lips,
it ran fine until May and it died out of no where with that single red light on the PCIE connector,
RAM'd again and got another one (red lip) and that one died the same way within 4 days but it was a different power connector this time,
it happened every time when they were underload, i ran stress tests and they all ran fine for even 40 plus minutes,
Finally i got the replacement 2 weeks ago and is working just fine including some test, gaming and my work related stuff,
Just learnt that the main problem in these are because of the cheap voltage regulators and stuff, which causes power draw issues specially with one of the PCIE connector,
attaching the image with power draw under load,
does it seems right or should i be concerned as I'm planning to re mount my hybrid cooler on it and its super annoying to remove it if it dies again,
Thanks
8 Replies Related Threads
    sidewaysout
    Re: 3090 FTW3 Power draw 2021/06/11 13:51:23 (permalink)
    upgrading you PCU and temperature control maybe? External temperatures and humidity can affect the connectors as well, especially in coastal areas with salt in the air
    hassou
    Re: 3090 FTW3 Power draw 2021/06/11 14:16:57 (permalink)
    Thanks and do you mean PSU? External temperature is well controlled plus my room is fairly dry than the rest,
    Dont you think that could be effecting or targetting the same card only?
    It never happened in my previous cards 1080 and 2080, all ran fine
    • Ribbons : 271
    Re: 3090 FTW3 Power draw 2021/06/11 14:34:12 (permalink)
    Power-wise, yours looks better than many I have seen. You must have gotten one of the new revisions. I wouldn't be concerned about it.
    sidewaysout
    Re: 3090 FTW3 Power draw 2021/06/11 14:52:07 (permalink)
    sorry misspell. Psu* Power Supply Unit, sometimes off brand power supply units may cause issues at max voltage since the 3090 has such a high wattage
    sidewaysout
    Re: 3090 FTW3 Power draw 2021/06/11 15:03:21 (permalink)
    As long as they keep on replacing it
    razor_pk
    Flagged as Spam (1)
    Re: 3090 FTW3 Power draw 2021/06/11 15:49:42 (permalink)
    Claim warranty before it goes dead .
    sidewaysout
    Re: 3090 FTW3 Power draw 2021/06/11 15:51:32 (permalink)
    razor_pk
    They have so much back stock to replace dead ones maybe thats why we cant buys any
    hassou
    Re: 3090 FTW3 Power draw 2021/06/11 22:22:57 (permalink)
    Hahaha yeah prolly so many issues and sorry my specs i forgot to mention,
    Im using top tier PSU as well with the cables provided,
    EVGA supernova 1600 p2
    Meg x570 godlike
    128gb ddr4 3200
    Ryzen 5950x
    2 x EVGA 3090 FTW3 ULTRA GAMING
    Thanks
