3070 Ti FTW Ultra fan speed
essex23
2021/10/03 22:05:21 (permalink)
So I just got my new 3070 Ti and when I put it in and booted, I automatically got a firmware update...and when it started, the fans IMMEDIATELY went to full speed and scared the crap out of me....then it went back to silent.   Ok...don't give me a heart attack like that EVGA!!!
But as soon as I turned on one of the only games I am playing lately....namely DayZ, as soon as I got past the loading screen and into the game, the fans almost immediately spun up.  Not like the firmware update, but loud enough to sound like a small vacuum.   Is there a way to set these fans to silent operation?   I mainly game at night when the wife goes to sleep, and I can already tell you, this won't fly.
"I don't break the rules.  I just bend them...A LOT!"  - Sideswipe
CPU: Ryzen 5800X @ 4.0 GHz with 280mm Corsair H110i V.2 AIO cooler
MB: EVGA X570 FTW
RAM: 32gb Corsair Dominator Platinum RGB @ 3600 MHz
GPU: 3070 Ti FTW3 Ultra
Power Supply: EVGA SuperNOVA 1000 P2
Primary Monitor: LG 34GP83A-B 34 Inch 21: 9 UltraGear Curved QHD (3440 x 1440) 1ms Nano IPS Gaming Monitor @ 160Hz
Keyboard: Corsair K70 Mk 2RGB
Mouse: Corsair Glaive Aluminum RGB
6 Replies Related Threads
    joseph305
    Re: 3070 Ti FTW Ultra fan speed 2021/10/04 08:03:51 (permalink)
    Yeah, it almost gave me a heart attack too !
    I have same problem, fans are loud ! especially the 3rd fan !
    I was going to do a rma, but re-installed x1 and tinkered with the fan curves
    I found the 1st fan good even at 100% , middle fan ok @ 100% but does make some noise,
    the 3rd fan even at 70% is very loud !
    So, I just used the pre generated fan curves and set it to stealth and that runs all benchmarks and games quiet, even when gpu temp hits 76 C ... because I lowered the #3 fans rpm a little also
    Still seems like a faulty #3 fan...
    10700, msi z590 mb ,16gig ram, 3070ti ftw3 ultra, win 10  , crucial m.2's
    essex23
    Re: 3070 Ti FTW Ultra fan speed 2021/10/04 08:28:27 (permalink)
    joseph305
    I still don't even know how to set the fan curve...not a lot of instructions on how to do so.
    I just had DayZ running, and was on for barely 3 minutes when the fans, or maybe just one fan, just suddenly went into 747 jet engine mode...I can't deal with that!   I use my PC for work as well as gaming, and I need to fix this now.   And I cannot for the life of me figure out why the fans or fan is speeding and ramping up when I am doing absolutely nothing and I am just sitting at the Windows desktop.
    I figured out how to use the X1 software to set the fans on "Stealth".....but they are still very much not stealthy at all, so any help in getting these fans to be in some sort of silent mode would be great.
    post edited by essex23 - 2021/10/04 11:46:14
    MB: EVGA X570 FTW
    joseph305
    Re: 3070 Ti FTW Ultra fan speed 2021/10/04 14:00:10 (permalink)
    so, you are on normal bios ? or oc bios ? that is a difference on fan speeds at temps below 55 degrees C... normal bios switch fans come on around 55 C with default settings...
    I'm just learning about x1 also, so you probably know as much as me !
    I 'unlinked' the fans in x1 then set each fan one at a time to xx% speed and
    then hit apply , just to hear how loud each fan is... so, you can listen and experiment
    on what each fans noise level is .
    You can then link them back up at test all 3 at same time ...
    If you put the software on stealth and it was loud , how about trying quiet mode ?
    Which fan is the culprit on noise ?? same as mine ? #3 ??
    Are you monitoring temps when you game ? say with HWmonitor ? or HWinfo64 ? both
    excellent free programs
    staypuft
    • Ribbons : 31
    Re: 3070 Ti FTW Ultra fan speed 2021/10/04 14:12:56 (permalink)
    If you want to reduce thermal load and fan speed, try "undervolting"... or FLVOC (Fixed Low Voltage OverClocking).  Combine that with a power limit.  Also try a frame cap in your game.
    If you suspect that a fan is bad, reach out to EVGA service.  Create a new ticket / submit a question.
    Interested in a discount on EVGA products?
    Click here for details and enter this Associates code at checkout >> 2ILPLQQ8IWY8DPN
    2021 Build: Gigabyte Z590 Ultra | Core i7-10700K | be quiet! Dark Rock Pro 4 | 32GB G.Skill Trident Z DDR4-3200
    EVGA RTX 3080 FTW3 Ultra | Samsung 970 EVO 500GB | Seasonic Focus GX-850 | Fractal Design Meshify C | Asus TUF VG27AQL1A
    Back_Yard_Gamer
    Re: 3070 Ti FTW Ultra fan speed 2021/10/06 03:37:57 (permalink)
    Fitted mine yesterday and set the fans to quite mode and linked the fans as well. Running A-OK and fans are not so to noisy. Fab GPU BTW.
    Professional Spammer with a PHD in Spamology & The Illogical Logic of Spam. Author of "Would you like cheese with that Mr Mann?"
    My living Room Please don't put yer feet on the table, its new!
    joseph305
    Re: 3070 Ti FTW Ultra fan speed 2021/10/06 08:49:21 (permalink)
    yeah, seems like 'quiet mode' is easiest way to keep card quiet with x1 ... especially if
    you don't know much about x1 software...
