Helpful Reply3060ti power consumption
homestyle
Thursday, September 09, 2021 4:45 AM (permalink)
I'm looking at 2 3060ti models. The 3060ti XC Gaming and FTW3 model.
If anyone has one of these, can you please let me know:
1. Video card wattage during load with power target at default (which would be 100)
2. Minimum and maximum power slider numbers (ie 75 to 109)
Thank you.
CraptacularOne
  • Ribbons : 222
Re: 3060ti power consumption Thursday, September 09, 2021 5:26 AM (permalink) ☄ Helpfulby homestyle Thursday, September 09, 2021 7:42 AM
I have a 3060 Ti FTW3 that at default pulls just over 220w with stock clocks and with a 108% power target and a +100 core, +1000 memory pulls 270w. Core clocks over clocked are 2055Mhz, and memory at 16Ghz.
Intel i9 14900K ...............................Ryzen 9 7950X3D
MSI RTX 4090 Gaming Trio................ASRock Phantom RX 7900 XTX
Samsung Odyssey G9.......................PiMax 5K Super/Meta Quest 3
ASUS ROG Strix Z690-F Gaming........ASUS TUF Gaming X670E Plus WiFi
64GB G.Skill Trident Z5 6800Mhz.......64GB Kingston Fury RGB 6000Mhz
MSI MPG A1000G 1000w..................EVGA G3 SuperNova 1000w
homestyle
Re: 3060ti power consumption Thursday, September 09, 2021 7:43 AM (permalink)
CraptacularOne
What is the minimum power target?
eagle74
Re: 3060ti power consumption Thursday, September 09, 2021 5:11 PM (permalink) ☄ Helpfulby homestyle Friday, September 10, 2021 3:49 AM
I have the 3060 Ti FTW3 Ultra which has about 5-8% factory OC.  The highest power draw so far is 235 w at ~95% usage, running 1080p with uncapped frames.  I believe that EVGA set a 240 w PL for this card.
CraptacularOne
  • Ribbons : 222
Re: 3060ti power consumption Thursday, September 09, 2021 6:47 PM (permalink) ☄ Helpfulby homestyle Friday, September 10, 2021 3:49 AM
homestyle
CraptacularOne
You can set it all the way down to 41% if you really want to. Not sure why you would want to do that and not just get a lesser card to begin with though.
eagle74
Power target is indeed set to 240w at default with a max of 260w on the FTW3 models. Though mine does spike to 270w at times.
https://www.techpowerup.com/vgabios/227067/evga-rtx3060ti-8192-201028
The XC models have power targets of 200w with limites at 220w.
https://www.techpowerup.c...-rtx3060ti-8192-201028
