YesRushGen
Wednesday, December 19, 2018 2:23 PM
Hello, I have an EVGA 550W G2 PSU powering my old Pentium 4 rig. The motherboard requires a 20pin connector - I've been using a 24pin female to 20pin male adapter cable. This makes for messy cabling. So question: Does EVGA make a dedicated 20+4 pin cable that I could use? Thanks, Kelly
- Ribbons : 282
Re: 20+4 pin instead of 24 pin cable
Wednesday, December 19, 2018 6:13 PM
Did not find one But the other PSU do like the 600-850 below do, also most if not all the cables are not interchangeable like the G2 EVGA 600 BR, 80+ BRONZE 600W, 3 Year Warranty, Power Supply 100-BR-0600-K1EVGA 600 B1, 80+ BRONZE 600W, 3 Year Warranty, Includes FREE Power On Self Tester Power Supply 100-B1-0600-KREVGA 600 BQ, 80+ BRONZE 600W, Semi Modular, FDB Fan, 3 Year Warranty, Power Supply 110-BQ-0600-K1EVGA 600 W1, 80+ WHITE 600W, 3 Year Warranty, Power Supply 100-W1-0600-KREVGA 600 W1, 80+ WHITE 600W, 3 Year Warranty, Power Supply 100-W1-0600-K1550 EVGA 550 N1, 550W, 2 Year Warranty, Power Supply 100-N1-0550-L1700 EVGA 700 BR, 80+ BRONZE 700W, 3 Year Warranty, Power Supply 100-BR-0700-K1 750 EVGA 750 N1, 750W, 2 Year Warranty, Power Supply 100-N1-0750-L1EVGA 750 BQ, 80+ BRONZE 750W, Semi Modular, 5 Year Warranty, Includes FREE Power On Self Tester, Power Supply 110-BQ-0750-V1EVGA 750 GQ, 80+ GOLD 750W, Semi Modular, EVGA ECO Mode, 5 Year Warranty, Power Supply 210-GQ-0750-V1EVGA SuperNOVA 750 PQ, 80 Plus PLATINUM 750W, Semi Modular, EVGA ECO Mode, 10 Year Warranty, Power Supply 210-PQ-0750-X1850 EVGA 850 BQ, 80+ BRONZE 850W, Semi Modular, 5 Year Warranty, Power Supply 110-BQ-0850-V1EVGA 850 GQ, 80+ GOLD 850W, Semi Modular, EVGA ECO Mode, 5 Year Warranty, Power Supply 210-GQ-0850-V1EVGA SuperNOVA 850 PQ, 80 Plus PLATINUM 850W, Semi Modular, EVGA ECO Mode, 10 Year Warranty, Power Supply 210-PQ-0850-X1 Looking at each of the ones below to see if they have a 20+4 None have a 20+4. Compatibility of the EVGA SuperNOVA 550 G2, 80+ GOLD 550W, Fully Modular, EVGA ECO Mode, 7 Year Warranty, Includes FREE Power On Self Tester Power Supply 220-G2-0550-Y1 (220-G2-0550-Y1)
post edited by bcavnaugh - Wednesday, December 19, 2018 6:53 PM
bob16314
- Ribbons : 761
Wednesday, December 19, 2018 6:26 PM
Just use the PSU's 24-pin connector in the 20-pin motherboard socket with the 4 pins from the 24-pin connector hanging out over the end of the 20-pin motherboard socket and doing nothing.
- Ribbons : 86
Wednesday, December 19, 2018 6:30 PM
bob16314 Just use the PSU's 24-pin connector in the 20-pin motherboard socket with the 4 pins from the 24-pin connector hanging out over the end of the 20-pin motherboard socket and doing nothing.
+1 to what Bob has said.
- Ribbons : 282
Wednesday, December 19, 2018 6:45 PM
I have one Motherboard I did this with but had to cut the 24-Pin to allow it to plug in. Most of the new Solid 24-Pin Connectors do not work, some of the Older Solid ones has a niche cut on them to use in a 20 Pin connector. I have Two motherboards that are only 20 Pin and I cannot use a 24-Pin Cable as it is blocked by a Capacitor that is next to the 20-Pin Connector on the Motherboard. I have one Dell Motherboard that has a 20-Pin Power Connector and a 4-Pin that is 2 Inches away from the Main 20-Pin Connector. I have an HP that has only a 20-Pin Connector that the size of the 24-Pin is 1/8 of an inch to big. Just saying this is not always going to work.
post edited by bcavnaugh - Wednesday, December 19, 2018 6:59 PM
bob16314
- Ribbons : 761
Wednesday, December 19, 2018 7:04 PM
bcavnaugh I have one Dell Motherboard that has a 20-Pin Power Connector I have an HP that has only a 20-Pin Connector that the size of the 24-Pin is 1/8 of an inch to big.
Sorry for your luck there, but 24-pin mobo connectors are backwards compatible with 20-pin mobo sockets, and vice-versa..The extra 4 pins are for PCIe slot power.
- Ribbons : 282
Wednesday, December 19, 2018 7:10 PM
bob16314
Yes I do know this but thank you for telling me. Just saying this is not always going to work on Pentium 4 and Older Motherboards with IDE & Floppy Connectors on the Motherboard.
post edited by bcavnaugh - Wednesday, December 19, 2018 8:50 PM
YesRushGen
Wednesday, December 19, 2018 7:11 PM
Thanks everyone. I don't think the overhang method will work. The mobo is an Intel D865PERL; the 20 pin connector is right against one of the PATA connectors. I did just discover - it looks like their custom ATX 24 pin connectors are of the 20+4 variety - according to the picture anyway. I have sent a message asking for verification. Kelly
- Ribbons : 282
Wednesday, December 19, 2018 7:15 PM
