Helpful Reply2 pin spdif cable for hdmi sound Connecting a gtx 275 to 790i ulta sli or x-fi titanium
Sealab2021
2009/12/25 20:42:46 (permalink)
I don't think the sound card has the 2 pin connector but I cant be sure.  If some one could confirm or deny, Also if some one could point out the 2 pin spdif that I'm supposed to plug into on my 790i ultra sli mobo it would be appreciated.  Thanks, and if for some reason the 790i doesn't have one, can I have a tissue.
  • Ribbons : 135
Re:2 pin spdif cable for hdmi sound Connecting a gtx 275 to 790i ulta sli or x-fi titanium 2009/12/25 21:03:23 (permalink) ☄ Helpful
Sealab2021
The x-Fi titanium doesn't have the proper SPDIF connector. Normally the cable if you got one, comes with the GPU not the mother board.
If you didn't get one you can get it from EVGA here: http://www.evga.com/products/prodlist.asp?switch=4
Here is the cable in how it is connected:
Here is where. The cable is connected the same on 680i/780i/790i boards. The picture is wrong and the connector should be rotated 90 deg clockwise so it is on pins 3 and 5.
post edited by HeavyHemi - 2009/12/25 21:05:25
vernacular
Re:2 pin spdif cable for hdmi sound Connecting a gtx 275 to 790i ulta sli or x-fi titanium 2013/07/20 11:20:24 (permalink)
Sorry for bumping this old thread.
So if the previously posted photo is incorrect and I must turn clockwise from what is shown then surely this is correct? I think these are pins 3 & 5, however the diagram and what is shown on the board itself suggest the red wire should be on the other side on the center pin.
EDIT: Nevermind, I figured it out. It does go the other way:
post edited by vernacular - 2013/07/20 16:49:47
CASE: Lian Li O11-Dynamic (Alpine White) .. MOBO: GIGABYTE Z390 Aorus Master .. CPU: Intel i9-9900K w/ EK Supremacy EVO Nickel .. GPU: EVGA 2080 Ti XC Gaming w/ Phanteks Glacier Waterblock .. RAM: Corsair Vengeance RGB Pro 16GB DDR4 3200Mhz .. RADs: 360mm + 240mm .. PSU: Seasonic Prime 1300w .. DISPLAYs: Asus PG297 + XP-Pen 15.6 .. OS: Windows 10 Pro
