LucidWaker
From the pictures that kinda look like box art on the 1080 Ti FTW3 you can somewhat see where all the RGB lighting goes that we all love to need to have nowadays (or something). But, what is "RGB LED G/P/M" though? The 1080 Ti SC2 only has "LED G/P/M", only white probably. I've seen the letters GPM on the 1080 FTW2 cooler banner (Gaming with Peace of Mind?) but I figure these light up from the same central LED lighting as the rest of the banner. Now, on the 1080 Ti FTW3 we see a white (likely to be RGB) brand/type statement but also three small LED's (blue/green/blue). These are white on the 1080 Ti SC2 pictures. What is "G/P/M", is it somehow related to the three smaller LED's? Maybe they're supposed to be letters but they aren't rendered properly? Only saw the letters on the 1080 FTW2 when I saw some real life pictures of it, and thought it didn't look that great...
Silverstone FT02B-W | ASUS Z170 Pro | i5 6600K | 16GB RAM | 2x EVGA GTX 1080 FTW ACX3.0 SLI]
the_Scarlet_one
formerly Scarlet-tech
- Ribbons : 79
Re: 1080 Ti FTW3 RGB LED "G/P/M"?
2017/03/28 05:23:42
Gpu core temperature, Power temperature (vrm's), Memory Temperature.
The start green, turn yellow when warm, and red when hot, and you can adjuet them to be whatever colors you prefer. RGB "GPM"
The SC2 with icx technology has this as well. The SC Black does not have this feature.
LucidWaker
2017/03/28 06:47:52
Thanks for that clear answer! Now time for some more contemplation on what to do with my 1080 FTW, go the SLI route (for crazy fun and bragging rights, plus gaming on 4K tv) or sell and go to 1080 Ti FTW3 (sensible super fast single GPU solution, also very fashionable)...
acemaninwa
2017/03/31 14:33:40
They actually turn green not yellow for the mid temp. So blue, green, red
Mitzrael
2017/09/17 06:11:45
I think mine have a problem, when the memory get to 60 degree, the G turn green not the M, and in precision XOC it is the memory that have turn green not the GPU, must have been inverse on my GTX1080Ti Hybrid FTW3...
Andrew_WOT
2017/09/17 08:16:20
Update XOC, there was a problem with FW
PietroBR
- Ribbons : 7
2017/09/17 16:06:18
LucidWaker Thanks for that clear answer! Now time for some more contemplation on what to do with my 1080 FTW, go the SLI route (for crazy fun and bragging rights, plus gaming on 4K tv) or sell and go to 1080 Ti FTW3 (sensible super fast single GPU solution, also very fashionable)...
I would recommend going with a 1080Ti alone, for the moment. 1 - It`s a stronger card; 2 - Not all games have good SLI profile to take advantage of it. But, that's just my opinion.
stealbmin
2018/01/29 16:30:46
what does it mean when the G/P/M led is blinking red?
AHowes
- Ribbons : 27
2018/01/29 16:45:06
stealbmin what does it mean when the G/P/M led is blinking red?
Call evga customer support on the phone and find out real quick. Don't sound good.
supernova6891
2018/01/29 16:53:06
the_Scarlet_one Gpu core temperature, Power temperature (vrm's), Memory Temperature.
VERY HELPFUL!! thank you!!
Shake & Bake EVGA Master raceCake & Snake Who Dat Boi :)
