Re: Water cooling the 970 SSC ACX2.0+ (and FTW+)
2015/05/06 10:47:24
Yeah it is the part what you need to aim fans directly at the card i was hoping to not have to do. Just having the case airflow dissipating the heat.
If you spend the cash for a custom loop for the silence and the looks the last thing you want to do is add an "ugly loud fan" in the middle of the case.
