Hekkel
Hello everyone, first of all I want to say that this is my first post here and I'm kind of new in all this(computer upgrading), and that english is not my main language so any advice will be apreciated.
To the topic.. about 4 months ago I bought a Evga Gtx 970 (had a gtx 750 before), so the first thing I did when I installed the gpu was playing GTA V (after optimizing with Nvidia Geforce Experience) .. and I noticed a lot a fps drops.. and some strange horizontal lines (the lines lasted almost nothing, but still annoying), specially when i was riding a car and turned (the best representation i found is this: ). So I turned the graphics on a lower setting.. (remember I optimized using Nvidia Experience).. i kept turning the graphs lower until I noticed a smooth gameplay but then i realiced I was playing on the (almost) same graphics as I used to play when I had my GTX 750.. after that I never played gta again (rage quit).. But a couple days ago I bought Diablo 3.. 2012 game and again I found myself turning some graphic options off or lower to run it smoothly (like micro lag spikes again, no horizontal lines this time).. I dont know if i expected too much for this gpu.. but I belive something's wrong. Any idea what could it be?
My PC specs:
Intel I7 4770k 3.5ghz 8Gb ddr3 1600 EVGA GTX 970 4GB Z87 PRO (V Edition) 24" Monitor (Samsung T24B350) 21" Monitor (Samsung S22D300) (I desactivate it when I play) 128GB Toshiba SSD 1Tb Western Digital Blue All my drivers are updated.
Thanks in advance!
Re: Possible problems with my Evga Gtx 970
2016/05/04 16:36:50
☄ Helpfulby XrayMan 2016/05/04 19:00:56
#1 Never use/install geforce experience. #2 Perform a clean install of most recent video drivers. (#2)#2 Delete game .cfg files and let the game/games rebuild them on next start. #4 Adjust game settings manually. Report back with how your games are working after doing the above steps.
DeathAngel74
- Ribbons : 10
2016/05/04 17:17:25
☄ Helpfulby XrayMan 2016/05/04 19:01:06
#5 Always perform a clean install of drivers if you experience issues after installing a new card. 362.00 will suffice #6 Try add another 8GB of RAM(total of 16GB) #7 What PSU are you using and how old is it?
post edited by DeathAngel74 - 2016/05/04 17:21:30
Carnage specs: Motherboard: ASUS ROG STRIX X299-E GAMING | Processor: Intel® Core™ i7-7820x | Memory Channels#1 and #3: Corsair Vengeance RGB 4x8GB DDR4 DRAM 3200MHz | Memory Channels#2 and #4: Corsair Vengeance LPX Black 4x8GB DDR4 DRAM 3200 MHz | GPU: eVGA 1080 TI FTW3 Hybrid | PhysX: eVGA 1070 SC2 | SSD#1: Samsung 960 EVO 256GB m.2 nVME(Windows/boot) | SSD#2&3: OCZ TRION 150 480GB SATAx2(RAID0-Games) | SSD#4: ADATA Premier SP550 480GB SATA(Storage) | CPU Cooler: Thermaltake Water 3.0 RGB 360mm AIO LCS | Case: Thermaltake X31 RGB | Power Supply: Thermaltake Toughpower DPS G RGB 1000W Titanium | Keyboard: Razer Ornato Chroma | Mouse: Razer DeathAdder Elite Chroma | Mousepad: Razer Firefly Chroma | Operating System#1: Windows 7 SP1 Ultimate X64 | Operating System#2: Linux Mint 18.2 Sonya (3DS Homebrew/Build Environment)
Hekkel
2016/05/04 18:36:33
@Sajin Awsome! It worked, now GTA is running smoothly even on higher settings and diablo too. I dont know what kind of wizard with magical thingy things you are.. but thanks again! @DeathAngel74 I'll probably buy more ram soon, and my psu is a 600w(or 650w) coolermaster.. may that be an issue?
2016/05/04 18:57:01
Hekkel @Sajin Awsome! It worked, now GTA is running smoothly even on higher settings and diablo too. I dont know what kind of wizard with magical thingy things you are.. but thanks again!
- Ribbons : 115
2016/05/04 19:03:00
Sajin #1 Never use/install geforce experience. #2 Perform a clean install of most recent video drivers. (#2) #2 Delete game .cfg files and let the game/games rebuild them on next start. #4 Adjust game settings manually. Report back with how your games are working after doing the above steps.
robbysites
fergusonll
2016/05/04 19:42:48
Yep, he's a magician when it comes to things like gpus , and I'm pretty sure he didn't need his wand for this one.
2016/05/04 22:38:20
fergusonll
ErinW
2016/05/05 03:40:29
I often use GFE when updating drivers, on a Windows Insider build, Express install. I figure that it I run into any issues, I can fix them. Aside from the recent SLI bug (unrelated to GFE), it has yet to cause my video cards to fly out of the PC, change the Windows start-up sound to "Pink Fluffy Unicorns Dancing on Rainbows", or spoil the milk in the fridge. Yes, there may have been bugs in the past, but if people don't install it, and report the bugs, they can't get fixed. Other than recommending to disable the Shield Streaming service (this has no effect on Twitch/Livestream streaming, etc.) if you don't have a Shield, GFE is quite harmless.
DeathAngel74
- Ribbons : 10
2016/05/05 07:11:05
GFE will change your Pepsi into Coke or vice versa while you sleep?
stalinx20
2016/05/05 09:16:36
EVGATech_ErinW
Can you forward a link to the "SLI bug"? I'm curious about this as I have not had experiences on this.
ErinW
2016/05/07 04:57:49
