Need help with choosing graphic card.
Diomar13
Thursday, October 23, 2014 7:58 PM (permalink)
Hi all. I'm new here so I hope I'm not in the wrong forum for the question. I'm giving my hubby for birthday all the components for him to build his own Gaming pc and I have an unopened GTX 770 Dual Classified with ACX now I'm thinking if I should do the step up program and exchange it for a GTX 970 and if I should I would like to know for which one should I exchange it. I thought about the EVGA GeForce GTX 970 FTW ACX 2.0. Would like your help on deciding what to do.
11 Replies Related Threads
    Sprinx
    Re: Need help with choosing graphic card. Thursday, October 23, 2014 8:20 PM (permalink)
    Diomar13
    Hi Diomar13, welcome to the EVGA forums. First off, it's pretty awesome of you to do this for your husband. My wife has more of a "tolerate" mentality towards my PC gaming, rather than "encourage." You're in the correct forum, but it might have been a good idea to create your own post for your question (you can still do this if you want - I'll copy/paste my reply).
    First, a few questions:
    What model is it exactly? I think it's 04G-P4-3778-KR, but just want to make sure
    When did you buy it?
    From whom did you buy it?
    Anyway, the step up from the 770 Classified --> 970 FTW would be a slight upgrade, but not earth-shattering. In fact many of the specs are pretty close if not the same. The main improvements are the slight increase in CUDA cores and the great improvement in power efficiency (means it will run cooler and use less electricity).
    The step-up program is actually designed for people who have already opened the box and started using their cards. Since you haven't even opened the box, are you able to return the card for a full refund to the store where you bought it? If so, do they charge a restocking fee, and how much?
    ASUS Prime X570-Pro AM4 | AMD Ryzen 7 5800X
    ZOTAC GeForce GTX 1080 Ti
    Corsair Vengeance RGB Pro 32 GB DDR4 3200
    Corsair Crystal 570X | Corsair CX-F CX750F PSU
    Corsair Hydro Series H100i RGB Platinum CPU AIO
    Secondary Tri-SLI just-for-fun 790i FTW rig: http://www.modsrigs.com/detail.aspx?BuildID=21014
    Fennicillin
    Re: Need help with choosing graphic card. Thursday, October 23, 2014 8:23 PM (permalink)
    The SSC or FTW are good choices. The SSC has a high factory overclock but the FTW has a higher factory overclock and improved power regulation. If he likes to tinker with overclocking the FTW will be worth the premium.
    Diomar13
    Re: Need help with choosing graphic card. Thursday, October 23, 2014 8:36 PM (permalink)
    Sprinx
    Diomar13
    Anyway, the step up from the --> would be a slight upgrade, but not earth-shattering. In fact many of the specs are pretty close if not the same. The main improvements are the slight increase in CUDA cores and the great improvement in power efficiency (means it will run cooler and use less electricity).
    Yes, thats the model I have. Its new but I took the UPC for the rebates with EVGA. I bought it from Newegg but I won't get refund from them due to removing the UPC from box.
    post edited by Diomar13 - Thursday, October 23, 2014 8:49 PM
    Diomar13
    Re: Need help with choosing graphic card. Thursday, October 23, 2014 8:38 PM (permalink)
    He really plays GW2 right now but I want him to be able to play any kind of game he wants too. About overcloking I really dont know his preferences casue his actuall pc is like 6 years old has a GTX280 and he uses a tv as monitor.
    Fennicillin
    Re: Need help with choosing graphic card. Thursday, October 23, 2014 8:44 PM (permalink)
    Diomar13
    SSC would probably be the way to go then, but if his PC is 6 years old there's probably other components that would limit him from playing modern games.
    Diomar13
    Re: Need help with choosing graphic card. Thursday, October 23, 2014 8:48 PM (permalink)
    Fennicillin
    Diomar13
    He will be have all new components to build his own gaming pc.
    Sprinx
    Re: Need help with choosing graphic card. Thursday, October 23, 2014 9:51 PM (permalink)
    Ah, if you've removed the UPC, then you cannot return it for full credit. Newegg would charge a restock fee (15% I think) anyway.
    If you want to upgrade, then the Step-up is your best option. Read through this, and do the steps in the second section if you decide to go forward with it:
    http://www.evga.com/support/stepup/
    Did you register the card yet? You can do this with your account you've already set up. Since the 770 Dual Classified is actually a little more expensive than the 970 FTW, you shouldn't have to pay any extra for the new card. You may also need to buy the extended warranty (should be about $20 for 5 year warranty), plus shipping your 770 back to EVGA, and then shipping to get your new card (maybe $20 more total).
    So, in total, you're looking at about $40 to get the newest technology, which in my opinion is not a bad deal. That's less than the potential restock fee with Newegg would be, even if you could return the card.
    Diomar13
    Re: Need help with choosing graphic card. Thursday, October 23, 2014 10:07 PM (permalink)
    I already bought the warranty and would only have to pay shipping. This is my build so far plus an ASUS VG248QE and planning on buying 2 more for a 3 monitor set up.
    Intel Core i7-4790K 4.0GHz Quad-Core/ Cooler Master Seidon 240M 86.2 CFM Liquid. Gigabyte GA-Z97X-Gaming G1 WIFI-BK ATX LGA1150 / Patriot Viper 3 16GB (2 x 8GB) DDR3-2133/ Corsair Force LX Series 256GB 2.5" SSD/Seagate Barracuda 1TB 3.5" 7200RPM/EVGA GeForce GTX 770 4GB Dual Classified ACX/Cooler Master HAF X ATX Full Tower/ EVGA 1000W ATX12V/ Asus BW-12B1ST/BLK/G/AS Blu-Ray/DVD/CD Writer / Microsoft Windows 7 Home Premium
    Sprinx
    Re: Need help with choosing graphic card. Thursday, October 23, 2014 10:23 PM (permalink)
    Diomar13
    Looks like a solid build. My only suggestion would be to use Windows 8.1 instead of 7, as it's doubtful if Direct X 12 will be supported on Windows 7 or not. But your husband can also just upgrade to Windows 10 in the middle of next year, if you've already bought a Windows 7 key.
    Since you've already bought the extended warranty, then you're all set. I would recommend getting the GTX 970 FTW ACX 2.0 04G-P4-2978-KR. It's the best 970 model that's available through the step-up program. The only better card is the 980, but then you'd have to pay a couple hundred dollars extra or so.
    Just go to your "My Products" page here on evga.com and request the step-up.
    Diomar13
    Re: Need help with choosing graphic card. Thursday, October 23, 2014 10:26 PM (permalink)
    I did it after seeing the responses. I'm on queue so hope it doesnt take too long. I need that part before last week of December. I bought the Windows 7 cause the person who helped me build the rig says most gamers prefer it. But like you said we can eventually upgrade if it is needed.
    warrior10
    Re: Need help with choosing graphic card. Thursday, October 23, 2014 11:41 PM (permalink)
    I'd go with Windows 8 myself. I don't know about 8.1. Glad u got ur step-up. And hope it arrives before Christmas.
    My new
    https://www.gigabyte.com/...70-Gaming-K7-rev-10#kf
    HAF-X Coolermaster: 4 Fans
    New Rig:Ryzen 1700 CPU-H100i Liquid arctic Cooled.
    16gigs Corsair Vengeance DDR4-2400
    180Ti Hybrid
    Blu-ray drive SCSI
    CDRW-RW drive SCSI
    Black WD Black caviar 2-1TB's and 1 500gig
    WD Blue 1 TB  1 Sand disk SSD 240 for OS
    Corsair PSU 1020
    SWTOR Mouse and Headset
    Razer CHROMA Keyboard
    Dell 1444p G-Sync Monitor @144htz to 160htz
