Re: Need Help! boot problem with my Geforce GTX 980 TI!
2015/07/06 21:11:33
Motherboard manual tell you what the beep codes mean?
In addition to Sajin's recommendation, intermittent sounds, to me, like something may be loose. If you haven't already, I'd make sure the card is properly seated in the slot and that the power plugs are in tight.
