Robbanswe
Re: Home-build a SR-2 with 6xGTX580 for rendering but it wont work ?,,need help please
2013/11/11 09:21:44
2x EVGA SR-2 with X5690, 48/96GB RAM. 1x intel Platinum 48core system with 9GPUS, 192GB ram all cpus\gpus watercooled 2x AMDThreadripper builds with 48GB ram,nvme raid. Intel 12900k,5xNVME raid, 3080,ddr5
TheWolf
- Ribbons : 9
2013/11/11 10:02:53
Code Dynamics That would be great robbanswe :), im messing up with gettin all cards recognized. Because i have "8"gpus, maybe a bios update would it make it happen that all 4 Double GPU cards will work and let me boot up the pc. @ the time i have 6 gpus aktive (3 cards), the 4 - dont let me pass with it booting up
Remember to write down any bios settings you have changed before a bios flash in case you may need those to try later on. It doesn't always erase the saved profiles, but there is always the chance it will, some have said A58 does erase the saved profile. Also to keep a certain bios that's on one of the 3 slots be sure to switch to the one you want to have flashed before the flash is started. Always drop any overclock back to default CPU clock before doing a bios flash. Be safe and good luck gett all cards working.
Robbanswe
2013/11/11 10:29:04
Hallo edu and wolf i turned off the hole audiosystem and its services.
TheWolf
- Ribbons : 9
2013/11/11 11:25:43
I have always turn off the SR2 onboard audio in bios since I could use a HDMI cable from video card to my monitor that has speakers and still have audio.
Robbanswe
2013/11/11 11:59:31
I turn it off to , Onboard sound is only 1 of crazy 30 in my SR-2 soundc on every grapcard is really annoying
LKrieger
2014/07/02 14:02:48
Amazing, This is really an extreme Ultra-End Build. Please make some more pics specific from the cards. LK
Robbanswe
2014/07/02 15:19:15
Yes, i can do that, in à couple of days. Regards Robban
gordan79
2014/07/03 02:10:58
If you are running out of PCI IOMEM (the 3GB Max setting in BIOS, you may have to modify the BIOS on your GPUs to reduce the aperture size. This may cost you some performance, but it will help with the IOMEM depletion. I don't think the SR-2 BIOS know how to map the 64-bit capable IOMEM blocks above the 4GB boundary, which is something that also breaks some Tesla cards, e.g. K40, which require a 16GB block.
Supermicro X8DTH-6, 2x X5690 Crucial 12x 8GB x4 DR 1.35V DDR3-1600 ECC RDIMMs (96GB) 3x GTX 1080Ti Triple-Seat Virtualized With VGA Passthrough (KVM)
Robbanswe
2014/07/03 11:19:06
This is 6 month Old,,, My computer works fine With 8x 580 gpu. Regards Robban
