spitonem
Got my new EVGA GTX 1070 SC and the fans are insane on it. Heres what i've done so far. DDU to remove old drivers Replace with 1070 and install drivers from website in top PCI slot. DDU to uninstall drivers. Reinstall drivers again. Move 1070 card to lower PCI slot. Reinstall drivers. Still wacky. The fans seem like they're either teetering on the edge of a sharp temp threshold on the fan speed curve or it's just a bad card. I haven't had a lot of exp with graphics cards so i'm at a loss. Stress test graphs I'm also uploading a video because the sound is really troubling. I'll edit when its done uploading youtube video is /watch?v=1-8XodyT3Ag You can see from this screenshot the fan speed is staying the same which make sense because the card is just idling. However the fan RPMs are going wild in response to absolutely nothing.
post edited by spitonem - 2016/06/30 07:43:41
Re: EVGA GTX 1070 erratic fans! HELP
2016/06/29 15:01:18
Sounds like the fan controller is going nuts.
trilegdog
2016/06/29 15:02:29
Asus Formula VIII, i7-6700k, Tt Riing 360 AIO, 16GB Corsair Dom/Plat 3K, EVGA GTX 1080Ti Black step-up, SS 850 Pro 512, 2xWD Blk 2TB, EVGA P2 1000w,Dual Boot Win7Pro64 /Win10Pro, Tt Core X-9, SS2693HM 1900x1200, Fuzzy Dice 6181-KR Step-Up began 29 June, queue hit 29 Aug = 62 daysRMA 980Ti SC+ to EVGA 31 Aug. Recvd by EVGA 10:41 am 2 SepUPS track # issued 8 Sep - delivered 13 Sep 2:54 PM ESTHYBRID AIO 400-HY-5188-B1 Ordered 8 July - Recvd 15 July EVGA 780i, E8400, 8GB OCZ (4x2), XPpro/Vista64 EVGA 8800 GTS G92 512 SLI (2), OCZ900MXS PSEVGA 7950 KO SLIlead, follow, or get out of the way
mpoffo
2016/06/29 15:14:50
So your running furmark ? Try Valley or heaven and see if it does the same thing.
X299 System: Windows 10 Pro 64-bit | Intel Core i9 7900x (4.4 GHz)| ASUS Rampage VI Extreme | 32 GB 3200 G.SKILL TridentZ RGB Corsair 900D | Corsair AX 1200i PSU | Corsair H115i Elite Capellix (in Push/Pull) | EVGA RTX 3090 FTW3 Ultra & 1080 8 GB Samsung 870 PRO 2 TB | Samsung 850 EVO 500 GB | Intel 520 SATA SSD 240GB HD | 2 & 4 TB WD Black Hard Drive Creative Sound Blaster Z | Logitech THX 5.1 speaker setup | LG Blu-ray burner | Corsair AF 120 and 140 Fans Acer x34 Predator (G-Sync) | 2 x Samsung SyncMaster PX2370
spitonem
2016/06/29 15:28:18
trilegdog Go to approximately 1:05 in the vid for fan spin up.
Thanks i forgot to mention i was too lazy to trim it. mpoffo So your running furmark ? Try Valley or heaven and see if it does the same thing.
I also have 3DMark and it does the same thing. Sometimes just idling at desktop with almost no programs running it will just spin up and stop. I called EVGA and downloaded the updated PrecisionX and changing the fan profile does absolutely nothing.
spitonem
2016/06/29 15:42:09
I cant PM because of my fresh account but if you could help me i'd really appreciate it. Or do you think its just a hardware problem?
coderz
2016/06/29 16:47:20
Can you post a screen cap of the fan curve you are using?
spitonem
2016/06/29 16:55:18
coderz Can you post a screen cap of the fan curve you are using?
Changing the fan profile in PrecisionX does absolutely nothing. I did some investigating and it looks like one of the screws on the back of the card is stripped and there are tool marks on the wires coming out of the 4 pin connector and scratch marks on the plate in the same area. I'm beginning to wonder if someone encountered the same problem, tried to half ass fix it, couldn't do it, so they resold it. I got it through a 3rd party through amazon but the packaging looked like it was straight from the manufacturer so idk.
stalinx20
2016/06/29 20:30:45
spitonem
duct tape lol
FattysGoneWild
2016/06/29 20:41:36
If you see marks like that and screws messed with. Hello Mcfly. That card has been tampered with from the start. And getting it from a 3rd party? Yeah good luck with that. Definitely a shady 3rd party. EVGA don't cover self damage. Even though you did not do it. And now your post has proof if you send it into them asking for help. I hope you get it taken care of or maybe be a bit more patient next time and get it from Amazon directly.
HP Omen 880-160se custom ordered OS: Windows 10 64 bit MOBO: HP Tampa2 CPU: Intel i7 8700k @4.8GHz RAM: 32GB DDR4 2400 GPU: PNY XLR8 RTX 3080 PSU: Delta 750w 80 Plus Platinum NVMe M.2 SSD: Samsung 512GB MZVLW512HMJP SSD: 250GB Samsung 860 EVO HDD: 2TB Seagate Barracuda ST2000DM001 Sound: Logitech Z623 THX 2.1 Speakers Monitor: Dell S2716DG 2560x1440 @144Hz G-Sync calibrated with ColorMunki Display Keyboard: HP Omen 1100 Mouse: HP Omen 600
Zaruchen
2016/06/29 21:07:55
that would be one hell of a situation..
Processor: Intel® Core™ i9-9900K CPU @ 5GHz Memory: 32GB @ 3600Mhz Hard Drive: 2x Samsung Evo 850 1TB, Samsung 970 Pro 1TB NVME Video Card: NVIDIA GeForce GTX 3090 Ti FTW3 + Hybrid Kit Motherboard: Asus ROG MAXIMUS XII HERO (WI-FI AC) Computer Case: Corsair 570x
spitonem
2016/06/29 21:32:28
What i am thinking is they built it and something was a little wrong like the wires got pinched between the heatsink and something so someone reached in there with a little screwdriver and tried to fix it. I really don't think someone had opened it. It was sealed so well and plastic the films were all perfect and whatnot. But there is obvious scarring on the wires near the 4 pin connector that controls the fans. I'll post pics where you can see sort of what i'm talking about. It was really hard to get a good picture with my phone. Imgur link endings. sorry my account is new /ZWOeSN7.jpg /UO4F5qT.jpg /zE7InJn.jpg
