EVGA 650 GS fan not spinning when testing with test 24 pin
InlusioX
Tuesday, January 05, 2016 10:54 PM (permalink)
Hi, I'm building my first PC and I'm kind of having a bad time with EVGA power supplies at the moment. I originally had the same power supply 2 weeks ago before purchasing a new one because I assumed the other one was dead. But now I'm having the same problem as before. I connect the motherboard 24 pin cable to the power supply, then connect the test 24 pin to it, plug the power supply into the wall with eco mode turned off, turn on power supply, and nothing happens at all. Eco mode is off and I've tried multiple different wall outlets and the same thing happens every time. It's extremely frustrating since it's my first PC build, so any response what so ever is appreciated!
Thanks,
InlusioX
14 Replies Related Threads
    bob16314
    • Ribbons : 761
    Re: EVGA 650 GS fan not spinning when testing with test 24 pin Wednesday, January 06, 2016 0:05 PM (permalink)
    Both the "old" and "new" PSU's EVGA 650 GS, right?..If so, did you use the same (old) cable for the new PSU?..What I'm getting at is that the cable might be bad like in posts #1 and #5 here..Yes, the fan should spin with the tester plugged into the 24-pin and the ECO Mode switch is Off.
    InlusioX
    Re: EVGA 650 GS fan not spinning when testing with test 24 pin Wednesday, January 06, 2016 0:29 PM (permalink)
    Both of the PSU's had the same problem. And I didn't use the same cable for both. old cable for old psu and new cable for the new psu.
    the_Scarlet_one
    formerly Scarlet-tech
    • Ribbons : 79
    Re: EVGA 650 GS fan not spinning when testing with test 24 pin Wednesday, January 06, 2016 0:34 PM (permalink)
    Did you try it with eco mode on by any chance?
    I noticeD that Johnny Guru mentioned that the eco mode switch was kind of backwards on one of the gpu's. Maybe it needs to be on, so it will be off?
    InlusioX
    Re: EVGA 650 GS fan not spinning when testing with test 24 pin Wednesday, January 06, 2016 0:36 PM (permalink)
    Yep, tried that as well just to make sure.
    the_Scarlet_one
    • Ribbons : 79
    Re: EVGA 650 GS fan not spinning when testing with test 24 pin Wednesday, January 06, 2016 0:38 PM (permalink)
    And you are using a tester that came with the psu?
    I don't mean to play 20 questions, just want to make sure.
    bob16314
    • Ribbons : 761
    Re: EVGA 650 GS fan not spinning when testing with test 24 pin Wednesday, January 06, 2016 0:39 PM (permalink)
    You used another new AC power cable too huh?..And another new 24-pin tester?..If yes/yes, call EVGA support..Highly unusual you'd get two bad units in a row though.
    InlusioX
    Re: EVGA 650 GS fan not spinning when testing with test 24 pin Wednesday, January 06, 2016 0:42 PM (permalink)
    yes and yes. I thought it was extremely weird also. I'll call support probably tomorrow unless someone responds with some other ideas lol. Thanks for all the help guys!
    InlusioX
    Re: EVGA 650 GS fan not spinning when testing with test 24 pin Wednesday, January 06, 2016 0:43 PM (permalink)
    yep.
    sammieandkrisbey
    Re: EVGA 650 GS fan not spinning when testing with test 24 pin Wednesday, January 06, 2016 7:21 PM (permalink)
    RMA it I guess?
    InlusioX
    Re: EVGA 650 GS fan not spinning when testing with test 24 pin Wednesday, January 06, 2016 7:30 PM (permalink)
    Probably will.
    sammieandkrisbey
    Re: EVGA 650 GS fan not spinning when testing with test 24 pin Wednesday, January 06, 2016 8:01 PM (permalink)
    GL. :)
    fallensld
    Re: EVGA 650 GS fan not spinning when testing with test 24 pin Thursday, January 07, 2016 1:27 AM (permalink)
    I am having the exact same issue currently with the same model and wattage psu. Only built the PC a few weeks ago, all was working fine until monday eve when i tried to turn on my and it came on (leds fans evthingg etc.) for about a second and the turned off. disassembled everything an did an out of the box build with only the few relevant components and same thing. Used the tester and got the same behaviour, fan came on for about a second then off.
    InlusioX
    Re: EVGA 650 GS fan not spinning when testing with test 24 pin Thursday, January 07, 2016 6:28 PM (permalink)
    Well that sucks lol. But I never even had my PC working because of the power supply and my fan won't even come on :/ Good luck fixing your's though!
    Geoff1968
    Re: EVGA 650 GS fan not spinning when testing with test 24 pin Tuesday, January 12, 2016 5:13 PM (permalink)
    i ve just  Cross-shipped my G2 550 cause the fan does not spin eco"off" tech support said its most likely DOA
    i opened my own thread , loads of views but not a single reply ( retailer does not want to know) also my 1st build
    quite a lot PSU's failing like this lately..
    Great Support From EVGA though  :)
