Cougar Intros FV270 Case with Unique Three-sided Front and Panoramic Pillarless Design
  • Ribbons : 85
2024/04/16 05:55:55 (permalink)
https://www.techpowerup.com/321597/cougar-intros-fv270-case-with-unique-three-sided-front-and-panoramic-pillarless-design
Cougar today introduced the FV270, a unique take on the trend of cases with a pillar-less front-left corner. This case features a 5-sided body (excluding the top and bottom); with the tempered glasshouse wrapping around three sides, giving you a more panoramic view of the insides. Toward the front of the bottom compartment, is a uniquely positioned 120 mm intake fan that points diagonally. The entire case is positioned at a slight tilt. The upper compartment with the motherboard tray serves up room for graphics cards up to 45 cm in length, and CPU coolers up to 18 cm in height. Since there's no vent along the front-panel, the entire clearance of the graphics card is always available. The expansion slots can be rotated 90°, letting you vertically orient graphics cards (riser not included). The motherboard tray includes a graphics card anti-bending mechanism.
Besides the uniquely positioned front-bottom fan, two 140 mm fan vents are positioned along one the front-right diagonal side. Additionally, there is a massive 420 mm x 140 mm vent along the top-panel, letting you mount up to three 140 mm fans (or smaller). A 240 mm x 120 mm radiator can also be mounted along the bottom of the top compartment. The bottom compartment serves up clearance of up to 25 cm for PSUs, and a drive cage with two 3.5-inch/2.5-inch drive bays. Two additional 2.5-inch drives can be mounted behind the motherboard tray. The case comes in two variants—the FV270 RGB with five pre-installed RGB fans, and the FV270 base model, with just two included non-illuminated fans. The two each have color-based sub-variants of black and white. The case measures 268 mm x 512 mm x 530 mm (W x D x H). Front-panel connectivity includes two USB 3.2 type-A, and a USB 3.2 type-C (20 Gbps-capable). The company didn't reveal pricing.
That front fan dip is interesting.
1 Reply Related Threads
    Hoggle
    Re: Cougar Intros FV270 Case with Unique Three-sided Front and Panoramic Pillarless Design 2024/04/16 21:55:48 (permalink)
    I look at that front dip and think it looks cool... but I also know I would likely hate it because I would accidentally drop a screw into it sometime. Hopefully it's got a nice filter with space between it and the fan in case something does get dropped.
