Thermaltake Announces ASTRIA 600 ARGB Dual Tower CPU Cooler
  • Ribbons : 85
2024/04/30 00:08:09 (permalink)
https://www.techpowerup.com/321999/thermaltake-announces-astria-600-argb-dual-tower-cpu-cooler
Thermaltake today announced the ASTRIA 600 ARGB, a dual fin-stack type CPU cooler. The company had shown off the ASTRIA line of coolers earlier this year at the 2024 CES. The ASTRIA 600 leads the pack, being the heaviest model, with the most heat dissipation area from its dual-stack design. Its design involves a nickel-plated copper base, from which six 6 mm-thick copper heat pipes make their way through two aluminium fin-stacks with equal fin-pitch to each other. Both fin-stacks are capped by die-cast metal top-plates with ARGB lighting from 18 LEDs, each. Two 120 mm fans ventilate the fin-stacks.
Each of the two included 120 mm fans features a 40,000-hour rated bearing, and a 9-LED ARGB lighting that projects from the impeller hub. The fan takes in 4-pin PWM for its main function, turns at speeds ranging between 500 and 1,800 RPM, pushing up to 65 CFM of airflow, at 2.56 mm H₂O static pressure, and up to 26.8 dBA noise. Even with both fans in place, Thermaltake says you have clearance for 1.5x-tall memory modules (ones that have lighting or heatsink crowns). The cooler has a cooling capacity of 265 W, making it fit for any of the flagship desktop processors. Among the CPU socket types supported are LGA1700, upcoming LGA1851, LGA1200/LGA115x, AM5, and AM4. The cooler measures 124 mm x 137 mm x 160 mm (L x W x H). The company didn't reveal pricing.
That is one big CPU air cooler,
0 Replies Related Threads
