CORSAIR Introduces White RMx SHIFT PSU Series with Side-Mounted Connection
  • Ribbons : 85
2024/03/19 08:10:06 (permalink)
https://www.techpowerup.com/320564/corsair-introduces-white-rmx-shift-psu-series-with-side-mounted-connection
CORSAIR today launched a white color variant of the revolutionary RMx SHIFT Series of ATX 3.0 power supplies. RMx SHIFT, the world's first PSU with the DC connector panel on the side of the unit, quickly became a sensation among DIY PC enthusiasts after its launch last year thanks to cleaner and easier cabling than traditional power supplies. Available in 750, 850, 1000, and 1200 wattages, the RMx SHIFT Series exemplifies CORSAIR's commitment to addressing the evolving needs of its customers. With its repositioned side panel, builders have unobstructed access to all of its Type 5 Gen 1 micro-fit connections, making installation and maintenance painless. It also means less bending and twisting of the cables, removing unnecessary strain on the cables and connectors.
White models of RMx SHIFT address the overwhelming demand from the PC building community for more customization options to match a wider range of builds. The new white units retain all the features that have made the RMx SHIFT a market standout, including fully modular cabling, 80 Plus Gold-rated efficiency, premium 105°C-rated Japanese capacitors, and a 140 mm fluid dynamic bearing fan, while matching the clean aesthetic of white system builds.
With ATX 3.0 certification and PCIe 5.0 compliance, the RMx SHIFT Series is ready to power the latest systems, and includes a PCIe 5.0 12VHPWR GPU cable for use with modern graphics cards such as the NVIDIA GeForce RTX 40 Series.
RMx SHIFT PSUs and cables will fit in any PC case that supports ATX format and is at least 210 mm (8.3") wide. The PSU must also be accessible from the side when mounted in the case. To check case compatibility, please refer to the online CORSAIR PC Builder.
Availability and Pricing
The CORSAIR RMx SHIFT White series is available now from the CORSAIR webstore and the CORSAIR worldwide network of authorized retailers and distributors. The RMx SHIFT Series is backed by a ten-year warranty, alongside the CORSAIR worldwide customer service and technical support network.
To learn more about the CORSAIR RMx SHIFT, please visit: www.corsair.com/rmx-shift
It's a great looking power supply. I have the 1200 watt shift in black.
0 Replies Related Threads
