what could be the cause of this issue if i unplug the psu from the wall the next time i switch on the power the 5vsb and the onboard power button will just flash eventually the lights will stop and i am able to turn the pc on other than this it works flawless i can shut it down and it boots back up i just cant unplug it
first i tested the psu with the included jumper it powered right up then removed everything from the board still the same issue tested everything 1 part at a time even tried
system spec
1200 supernova p2 <- overkill what i got from rma
x99 classified bios v2.09
5930k 4.4 1.266v
evga 1080 ti sc2
CORSAIR Vengeance LPX 32GB (4 x 8GB) CMK32GX4M4Z3200C16
ezdiy-fab m.2 adapter pcie 3.0 x4 / hp ex920 1tb m.2 ssd
