Ghaschke
I was looking into water cooling and it looks like now it is a ton easier than it used to be. that being said is it the move?
Flint 1760
- Ribbons : 45
Re: water cooling or air
2021/09/29 10:13:08
That is totally up to you. I've been water cooling for a very long time and I still enjoy it, particularly the results. It does require more planning, more time to build, increased cost, and a little more maintenance.
evga1081
2021/09/29 15:11:47
If water cooling fails it cant destroy your entire PC. If you aren’t prepared for that, then spend your time looking at some quality/quiet air cooling with proper filters to reduce dust build up.
Flint 1760
- Ribbons : 45
2021/09/29 15:56:20
evga1081 If water cooling fails it cant destroy your entire PC. If you aren’t prepared for that, then spend your time looking at some quality/quiet air cooling with proper filters to reduce dust build up.
If you build it correctly, test it correctly, maintain it correctly, monitor it correctly, then the odds of a catastrophic failure are extremely small. I've had three failures in well over a decade, all were pumps, and the last was over five years ago. I knew about them almost immediately. Just a matter of shutting down, draining and flushing, and replacing the pump. This is also why I have spare pumps.
the_Scarlet_one
formerly Scarlet-tech
- Ribbons : 79
2021/09/29 16:55:11
Watercooling is fun, but very expensive. I have noticed recently that watercooling provides some improvement, but it has also gotten extremely expensive as the PCB’s have become more complex. If you are interested in watercooling, research everything you want, and match the components from a single vendor for the best results and longevity. It isn’t a requirement to match everything you can, but it helps your warranty with the company if everything comes from them. Make the decision if you are going to use any opaque fluids early, and be ready to monitor is closely. I did opaque fluids three times and every time it changed colors and became disgusting and also “stuck” to other components as well as falling out. Now I use distilled water and an inhibitor, and nothing else, because it’s just not worth it to me to deal with the opaque fluids. If you go watercooling and want to use RGB, make sure you know how to connect it and use it. I went with EKWB, and they use DRGB headers, and those header wouldn’t work with my motherboard, so I had to go out and find a completely separate controller for the RGB, making the setup even more expensive. Later I purchased the active backplate, and the RGB wouldn’t even connect connect to the blocks I was already utilizing, meaning I have to connect even more wires to the controller meaning more wires to figure out how to route. Aircooling doesn’t require any of these struggles, so this is probably going to be my last time watercooling, but only time will tell, because watercooling looks so much better.
post edited by the_Scarlet_one - 2021/09/29 16:59:18
Flint 1760
- Ribbons : 45
2021/09/29 17:04:52
^I tried opaque fluids once and never again. I clean and flush every six months and with opaque after six months it was a complete disassembly including blocks because of the gunk. Granted this was some of the early stuff, but it put me off all colored fluids, opaque or otherwise. Just glad I didn't use it in my wife's build.
Aapje
2021/10/01 08:02:08
I prefer air cooling due to the reduced risks and the simplicity. I think that a lot of people mainly do it for the looks, but I prefer closed, non-glass cases anyway (I prefer to look at pretty pictures on the screen, not the blinkenlights).
bob16314
- Ribbons : 761
2021/10/01 11:19:24
Up to you, really..Lots of informative articles on CPU and GPU Air vs Liquid Cooling and cooler reviews you can search for..There's good AIO liquid coolers that are more affordable and less hassle than DIY liquid cooling.
I went with an AIO (in my sig) to keep CPU core temps down because I always overclock.
As far as worrying about failing/overheating, I think everybody should have a program such as MSI Afterburner, HWiNFO, Real Temp, AIDA64 or whatever running where you can set alerts or to auto-shut down your PC at a user-specified maximum temperature.
tattude69
- Ribbons : 5
2021/10/01 12:48:42
It really depends on what you want? i started out using throw away AIO's for increased cooling/No maintenance and then Discovered AIO's that are expandable (AlphaCool Eisbaer) (Alphacool Eiswolf) out of the box improved performance with the ability to use the parts in a custom loop. Much better cooling as they use coper Radiator's vs the Aluminum most throw away AIO's use. I feel water cooling gives you more freedom to customize your build. If built correctly watercooling a pc is no different then how your car, or house use water. things can go wrong but proper planning and proper installation will minimize the risk involved. Proper leak test is the key. Use youtube and forums and don't be afraid to ask questions. These forums and youtube is how i learned.
crazyjohnny
2021/10/02 03:40:00
If you want to keep it simple, with minimum risks of damaging your PC, you can use AIO cooling. Of course there are pros and cons for each type of cooling, mainly on AIO there is a limited lifespan of the pump. The temperature differences are of course notable, but unless your are really into overclocking you can also use an air cooler. This video answered all my questions at the time and advise you to look into it: https://www.youtube.com/watch?v=7VzXHUTqE7E
rmorse27
- Ribbons : 19
2021/10/02 07:05:56
Intel i9 14900kf-Asus Z790 Rog Strix-E Wifi-Corsair 64GB @6400 DDR5-EVGA 3080TI FTW HC-EVGA G6 1000 PWS-Samsung Pro 2TB 4.0-Thermaletake Case-Corsair Pump/Res Combo http://www.heatware.com/eval.php?id=66896
jon321op
Flagged as Spam (1)
2021/10/02 11:52:06
Water cooling sounds better and looks better. hopes this helps
Ghaschke
2021/10/03 03:22:17
Yeah thats what i was thinking tbh air cooling seems so much easier
tehmon0
2021/10/03 11:58:11
crazyjohnny If you want to keep it simple, with minimum risks of damaging your PC, you can use AIO cooling. Of course there are pros and cons for each type of cooling, mainly on AIO there is a limited lifespan of the pump. The temperature differences are of course notable, but unless your are really into overclocking you can also use an air cooler. This video answered all my questions at the time and advise you to look into it:
Thanks for the information!
Ghaschke
2021/10/05 04:30:47
how long does it take for the pump to wear out on an AIO
Aapje
2021/10/05 04:50:08
☼ Best Answerby Ghaschke 2021/10/05 06:54:40
Ghaschke how long does it take for the pump to wear out on an AIO
It depends on how much your computer is on, the quality of the AIO and on luck. I most often see people arguing that it is 5 years of full-time.
Ghaschke
2021/10/05 06:54:58
thanks for all of the knowledge guys!
Epal2Apol
2021/10/05 11:44:24
7 Years for my first AIO (Antec), installed to an i7-2600K, year 2011. Rattling sounds for several months before it stopped pumping. Replaced it with CM Hyper 212 after. This is a 24/7 PC. It became noisy after the replacement. My second AIO is a Corsair (installed to i7-5930X), which is still serving me well since 2015. 5 years life span is good to say, and mostly their warranty is 5 years.
12G-P5-3967-KR 6/3/2021 12:16:53 PM PT YES 24G-P5-3987-KR 8/22/2021 8:42:12 AM PT No Patience is Virtue That I Don't Possess
freakdaddy64
- Ribbons : 5
2021/10/06 01:44:45
i went from a coolermaster blk rgb 212 to a nzxt 360mm rgb aio and my temps dropped 8 degrees and was my first liquid cool install and it went pretty easy and it looks great.
asus rog strix b550 f gaming ryzen 7 5800x3d cpu gskill trident z neo rgb ddr4 3600 ram sabrent 2tb ssd m.2 storage sabrent 1tb boot asus rog 4080 oc corsair 5000d case evga supernova 1000 t2 psu nzxt x73 rgb 360 cooler asus rog xg349c 34 inch display asus rog xg27aqm 27 inch 1440p 270 hz monitor THE SMOOTH OPERATOR Associate Code: YLOPU45V2M8FQL9 Elite ID: 2RWCT4B87YQYR15NNQO
stebru94
Flagged as Spam (1)
2021/10/07 06:18:55
water cooling for everyone!
cesarx
- Ribbons : 6
2021/10/13 03:39:21
Noctua NH-U12S chromax fully loaded for me
Gigabyte Z690 Aorus Elite........MSI Z690 Edge 12700k.......................................12700kf Red Devil 6950XT...........EVGA RTX2080 Super EVGA P2 850W.................EVGA GD 700W Rip Jaws 32GB 3600..........FlareX 16GB 3200 Sceptre P35..........................Sceptre P30
