supplemental 6 pin pcie power on lower left of motherboard.
elkido122
2018/08/05 22:07:39 (permalink)
is it required to run this if i am only using a single gtx 1080ti with a hx1000i psu.. its a solid psu and a single gpu so im not sure that it needs to be plugged in?.. thanks
3 Replies Related Threads
    turbomadman
    Re: supplemental 6 pin pcie power on lower left of motherboard. 2018/08/05 22:29:17 (permalink)
    Ok so if you got an X299 Dark it is optional if only running one card. This is straight off of the Evga Manual;
    "8. Supplemental PCIe 6-pin Power Connector There is a 6-pin PCIe connector at the bottom of the motherboard (See Page 48 for more specifics to the connector itself, and associated wiring/pinouts). This connector provides dedicated power to the PCIe x16 slots, augmenting the +12V power provided by the 24-pin and the GPU directly. This is optional for a single card solution, but is recommended for SLI, CFX, and dual-processor video cards".
    elkido122
    Re: supplemental 6 pin pcie power on lower left of motherboard. 2018/08/05 22:46:28 (permalink)
    good so not required
    • Ribbons : 84
    Re: supplemental 6 pin pcie power on lower left of motherboard. 2018/08/05 22:53:16 (permalink)
    elkido122
    Yes but if you do want to plug it in there are no problems.
