d3de58
Hello, how can i combine headphone AND spdif output ? when teamspeak problem will be corrected ? i was with asus xense ( = essence ) and i'm not happy with this 2 problems
d3de58
Re: spdif/headphone combine audio ? teamspeak problem
2020/01/01 05:01:35
- Ribbons : 84
2020/01/01 05:33:07
My suggestion is that you contact EVGA tech support directly.
d3de58
2020/01/01 06:23:26
how to ? i ordered not directly to evga
- Ribbons : 270
2020/01/01 07:33:15
- Ribbons : 84
2020/01/01 07:55:52
Make sure you registered your product before you call.
EVGA_Lee
Moderator
- Ribbons : 14
2020/01/02 15:07:52
d3de58 Hello, how can i combine headphone AND spdif output ? when teamspeak problem will be corrected ? i was with asus xense ( = essence ) and i'm not happy with this 2 problems
So, let's start with the first question. Essentially, you can't. The Speakers (which includes both the RCA out and Headphone Out) are considered one device by the OS, and the S/PDIF is considered a second device. In order to use one, the other must necessarily be turned off. Now, that doesn't stop you from trying different things. For example, an Astro MixAmp could be run through the NU Audio S/PDIF and you could connect your headphones. But that's not really ideal, and doesn't really utilize the strengths of the NU Audio or NU Audio Pro cards. Regarding the Teamspeak issue: I am aware the Nahimic can reproduce the issue. They are returning from their holiday break next week, I believe, so I can provide a better update then.
d3de58
2020/01/11 12:10:12
why Asus do it on Essence audio cards ? i can use both audio output without anyproblems
- Ribbons : 270
2020/01/11 12:40:41
d3de58 why Asus do it on Essence audio cards ? i can use both audio output without anyproblems
Why does Asus? I don't know. This isn't an Asus website. Why doesn't EVGA? I can only speculate: having longer trace length in circuit increases electrical interference, so switching between the outputs and using only one at a time could decrease electrical interference and improve sound quality. The fact is that there are relays (the "click" you hear when you switch outputs) which direct the sound to one or the other. Both outputs at the same time is physically/mechanically not an option for this product. The only way to change that is for you to void the warranty and take a soldering iron to your sound card.
d3de58
2020/01/11 13:05:24
very bad trip this Evga audio card, my old Asus had the same sound switch with mic/headphone but spdif is not by switches, not analogic circuit, full numeric.
