charbel1011
my rtx 2080ti. have 3 red lights on when i boot my pc from time to time. is this power issue? i have the corsair rm850. so.im guessing this psu is good?-
Re: red lights and fan issue.
2019/03/19 10:52:28
It's not a power issue. It means the card is stuck in flash mode. See if doing this will fix it.
charbel1011
2019/03/19 11:05:27
Sajin It's not a power issue. It means the card is stuck in flash mode. See if doing this will fix it.
it didn't fix it. what's that means? should i rma the card? if the replacement does the same thing. whats the solution?
2019/03/19 11:17:35
I'd contact evga support and see what they suggest. Some people have said they have fixed the issue by changing their motherboards.
charbel1011
2019/03/19 11:40:23
Sajin I'd contact evga support and see what they suggest. Some people have said they have fixed the issue by changing their motherboards.
but if i dont change my motherboard will that problem affect anything in my gaming performance?
2019/03/19 11:43:59
charbel1011
2019/03/19 11:50:58
Sajin Don't think so.
this is legit frustrating to me. i hate replacing my motherboard again. god.
2019/03/19 11:58:15
Another solution to the issue would be to swap your current 2080 ti ftw3 with a different 2080 ti model that doesn't have the three red lights built into it. A 2080 Ti XC Gaming Ultra would do.
charbel1011
2019/03/19 11:59:57
Sajin Another solution to the issue would be to swap your current 2080 ti ftw3 with a different 2080 ti model that doesn't have the three red lights built into it. A 2080 Ti XC Gaming Ultra would do.
yeah but evga wont do that though no?
2019/03/19 12:00:40
charbel1011
Yeah, I don't think they would exchange it for you, but it wouldn't hurt to try.
charbel1011
2019/03/19 12:06:30
charbel1011
iv been troubleshooting hardware and software issue for years. this is legit the first time i come across something like that. like im surprised evga or other companies didnt address this issue yet. like where its coming from so we can solve the issue.that's legit crazy. like i can swap the motherboard no problem. but what would assure me that it wont happen on the new motherboard.
A.Benov
2019/03/19 12:10:28
Just open my new 2080 FTW3 and have the same problem (MB: X99 Micro 2)
charbel1011
2019/03/19 12:15:25
A.Benov Just open my new 2080 FTW3 and have the same problem (MB: X99 Micro 2)
oh god. its like a viruse everyone is catching it. i dont know what else to do myself.
_JeffP
2019/03/20 02:01:40
Try re-seating your power supply cables, if the issue continues contact us through a support ticket on your registered product
charbel1011
2019/03/20 09:02:19
EVGATech_JeffP Try re-seating your power supply cables, if the issue continues contact us through a support ticket on your registered product
reseating my power cables have no effect on my card getting stuck in flash mode. look at other replies. see that guy he got a brand new 2080 and its doing the same problem. the evga tech's reply was i need to be looking at somewhere else. like where? motherboard? tell me what motherboad to buy and i will do it. im not gonna go pick a random motherboard that might have this problem too. my psu is new and good its corsair Rm850x. so plenty of power. im using no adapter or anything moded. im using the original psu cables and 2 pcie cables as well. so i dont know whats causing this problem. but we seriously needs a fix. i hope evga's engineering are really working on it.
A.Benov
2019/03/21 02:06:55
My 2080 FTW3 works fine with ASUS Z170 MAXIMUS VIII GENE. Change of bios settings of the X99 Micro 2 (and re-seating power supply cables) did not give a positive result
charbel1011
2019/03/21 03:40:38
A.Benov My 2080 FTW3 works fine with ASUS Z170 MAXIMUS VIII GENE. Change of bios settings of the X99 Micro 2 (and re-seating power supply cables) did not give a positive result
yeah and yet we didn't hear anything from evga. and they are only providing us by basic troubleshooting steps that has nothing to do with the actual problem. i dont get it how theres 0 input from them. and theres some good amount of people suffering from it.
