spit051261
Just tried my other CPU (i7-7740x) in my Dark and it just boots straight into bios all the time. I have tried using bios with newest update as well as the other two which have older ones. Just put the 10980xe back in and it works fine Any ideas guys ? just a thought , could it be the CPU not recognizing my M.2 ?
post edited by spit051261 - 2020/10/05 22:53:56
Gaming Rig - Lian Li Dynamic XL, MSI Z490 Godlike, i9 10900k (SP 88) delidded with Rockit IHS, G-Skill 4266 RAM 2X8 , MSI Z Trio 2080ti, Aorus RGB 360 AIO, EVO 2Tb 970 Plus Nvme,1600watt P2, Acer Predator X27 Monitor, K95 Platinum, G502,G560, ST100 RGB, Void RGB Elite.OC Rig - Lian Li T70, Apex XII , i9 10900k (SP 93) delidded with direct die cooling, G-Skill 4000 2X8 Cl15-16-16 RAM , Evga KPE 2080ti, 2 x 1 Tb Evo 970 Plus Nvme, Evga 1600watt P2, EXC 800 Chiller.
bob16314
- Ribbons : 761
Re: problem changing from 10980xe to 7740x on dark
2020/10/05 23:05:32
That CPU (i7-7740X) is shown as compatible with the board right from BIOS v1.00. Try completely decaying CMOS by unplugging the PSU and taking out the CMOS battery as described in the second method here..Then try again.
spit051261
2020/10/05 23:10:20
I have just checked BIOS and no nvme is recognized . Seems strange that the 10980xe sees it but this does not . Oh well.
bruno_ro
2020/10/05 23:15:39
Check page 29 from X299 Dark manual. You can find there the config of PCIE lanes for M.2 when using 7740X.
spit051261
2020/10/05 23:21:49
Sorted ....had to move the nvme with OS to the other slot
