power draw from my system PIC inside
logan801
2011/01/05 14:53:04 (permalink)
I saw this on a thread the other day and it spured me to go get one to see what my system was pulling. Here's a list of whats being powered off my psu: 10 fans, 2x570, 1cd drive, 1mb, 1cpu, 1water pump, 6ram sticks, 2hdd, 1ssd, 1usb mouse, 1usb keyboard, 1usb gaming controler. all of which were plugged in during this test.
19 Replies Related Threads
    z3r0t0l0rence
    • Ribbons : 20
    Re:power draw from my system PIC inside 2011/01/05 15:22:10 (permalink)
    Wattage meters a very useful in knowing how much your system is actually pulling.
    Nice work!
    i7 930 OC 4.21
    EVGA E758
    GSkill 12GB
    Evga GTX 780 SC
    2x Kingston 240 Raid 0
    2x Seagate 4TB
    logan801
    Re:power draw from my system PIC inside 2011/01/05 15:35:05 (permalink)
    thanks, thought it might help someone
    codeman
    Re:power draw from my system PIC inside 2011/01/05 15:55:41 (permalink)
    +1, thanks for providing that :)
    Intel i7 980x @ 4.48Ghz   || 12GB Mushkin Blackline  ||  Gigabyte X58A-UD5
    EVGA GTX580 with HeatKiller WB @ 900/2300 with 1.14 volts
    2x 120GB Mushkin Callisto Deluxe SSD's in RAID0
    1.5TB WD Green storage drive (excellent quiet drive with optimized vibration)
    Xonar Essence ST to Harmon Kardon AMP w/Klipsch floor monitors
    CaseLabs M*
    Enermax Modu87+ 800watt PSU
    27" Apple LED Cinema Display
    Windows 7 x64 Ultimate
    Mod Rig
    paavonurmi
    Re:power draw from my system PIC inside 2011/01/05 16:21:44 (permalink)
    I just got one of those, I hit 685 watts while playing metro 2033, at idle it's around 370 watts. I'm running 2x 570's, 6 sticks of ram, 1 water pump, 4 fans, 3 hdd, usb mouse, wacom tablet, 2 monitors, i 7 920@3.8
    pb680
    Re:power draw from my system PIC inside 2011/01/05 16:56:10 (permalink)
    Thanks I have mostly the same hardware, I was wondering where did you put 10 fans I have the same case and I have 7. 2 for the Cosair H50 push pull,1 under the hard drive cage,1 one the floor of the case,1 rear,1 at the top, and one behind the video cards.
    How do you like the Cosmos 1000 case?
    EVGA DG-87
    MSI X99A Gaming Pro Carbon
    INTEL CORE i7 5280K OC TO 4.5
    16 gigs G.SKILL RIPJAW MEMORY
    BENQ BL3200PT 32" MONITOR 2560X1440
    CREATIVE SOUND BLASTER Z SERIES
    LOGITECH Z906 5.1 500 WATT SPEAKERS
    CORSAIR H100i COOLER PUSH/PULL SET UP
    logan801
    Re:power draw from my system PIC inside 2011/01/05 16:56:38 (permalink)
    paavonurmi
    just ran 2 loops of metro only got up to 612w, but mine idles lower around 260w right now! yours is probably higher cuz of the two monitors
    logan801
    Re:power draw from my system PIC inside 2011/01/05 17:04:27 (permalink)
    pb680
    I like it but i had to do a lot of cutting to get all my rads and fans up top. should of got the 800d. BTW i have 2x240rads at the top theres 5 fans on those one at the back by the i/o's one at the bottom one at the end of the 570's one on the ram and one in the plexi glass.
    post edited by logan801 - 2011/01/05 17:07:50
    paavonurmi
    Re:power draw from my system PIC inside 2011/01/05 17:14:46 (permalink)
    logan801
    The cost feature is fun and scary, at least now I know why my power bill is so much lower when I'm gone on vacation for a couple weeks.
    logan801
    Re:power draw from my system PIC inside 2011/01/05 17:23:44 (permalink)
    yeah. i don't know if you have to calibrate these things but mine said 27$ when i was playing a game. good thing i live in an apt. and our power is subsidized muha ha muha ha
    paavonurmi
    Re:power draw from my system PIC inside 2011/01/05 18:00:12 (permalink)
    logan801
    You have to put in the price per KW, hold down the middle button for 5 seconds, then use the left and right buttons to change the price up or down.
    logan801
    Re:power draw from my system PIC inside 2011/01/05 18:43:20 (permalink)
    it was only off by 3c  total was 25$/kwh during gaming
    paavonurmi
    Re:power draw from my system PIC inside 2011/01/05 19:30:39 (permalink)
    I got mine yesterday and hit $29 per month while gaming. It does an average and I turn my computer off while at work, so now it's down to $19 per month.
    logan801
    Re:power draw from my system PIC inside 2011/01/05 19:48:30 (permalink)
    $30 bucks a month aint bad to have a little fun
    paavonurmi
    Re:power draw from my system PIC inside 2011/01/05 20:17:25 (permalink)
    I agree, 30 bucks a month is great fun to price ratio.
    pb680
    Re:power draw from my system PIC inside 2011/01/05 20:37:25 (permalink)
    I feel the same way when I purchased this the 800d had just been release and it was around $320 and this was just as big for $179. It works good for everything I have in it.
    Thanks for the response.
    EVGA DG-87
    paavonurmi
    Re:power draw from my system PIC inside 2011/01/05 20:52:06 (permalink)
    Have any more pictures of your case ?
    I have the cosmos 1000, but mine is stock. I love the case, but I tempted to get a mountain mods
    logan801
    Re:power draw from my system PIC inside 2011/01/05 21:17:47 (permalink)
    just this one
    Alucard666
    • Ribbons : 12
    Re:power draw from my system PIC inside 2011/01/05 21:20:39 (permalink)
    Nice. guess that means mine is pulling a little less probably in the 625-650w range
    AMD Ryzen 7 3700x | 32GB Crucial Ballistix PRO RGB 3600mhz| ASUS RTX 3080 TUF OC | ASUS X570i STRIX | 2TB Sabrent Rockit M.2 SSD| NZXT H1 w Ghost Sheets Mesh Front | Noctua 140mm & 2 40mm | Samsung Odyssey G7 32" | Logitech G Pro Wireless | Logitech G915 | SteelSeries Arctis Pro Wireless | Logitech G560 RGB Speakers |
    paavonurmi
    Re:power draw from my system PIC inside 2011/01/05 21:41:36 (permalink)
    Very nice, thanks for the pictures
