southlee
Hi I'm a noob from here. I update my z370 micro board yesterday, after that, my PC's beep the abnormal sound, (I attached the video clip here youtu.be/gQI0R5IE9KI ) Is anyone can let me know what's that mean, please? Or is there any software that I can check it by myself? Thank you!
post edited by southlee - 2019/12/28 00:37:51
southlee
Re: abnormal beep sound
2019/12/28 00:35:02
srry this page can not attach the video clip or youtube link.. youtu.be/gQI0R5IE9KI here is a video clip addreess
bob16314
- Ribbons : 761
2019/12/28 01:01:39
All that beeping (or most of it) probably corresponds to the number of USB devices attached to your PC, some motherboards do that and that would be normal..You can disconnect them and find out. You might be able to enable a Quiet Boot mode in the BIOS -> BOOT Options if it's annoying.
southlee
2019/12/28 18:31:25
2019/12/28 19:34:08
MhzManiac
- Ribbons : 8
2019/12/29 00:51:45
Funny, sounds just like mine.
That is me in the picture, anyone else ever pet a live Lion?EVGA Z390 FTW (Bios 1.08) i9-9900KF 8 core, 32G Corsair Vengeance LPX Dual Chl 3000 XMP-1 , Intel SSD6 M.2 2TB, Samsung 840 PRO 1TB / 512G SSD, Gigabyte RTX 2080 Super , Win 11 Pro 64, EVGA Supernova 1300 watts, NZXT Phantom 820, Strix Raid DLX 7.1 surround, Corsair H100 Liquid , Dell S2417DG /S2409W / Acer XB241H Predator / Samsung C24F390 Curve/ Oculus Rift S VR
kelkel1
2019/12/29 05:44:58
Others say normal, so I guess it is. I normally get no beeps at all or one short beep on my Dark.
2019/12/29 14:01:32
kelkel1 Others say normal, so I guess it is. I normally get no beeps at all or one short beep on my Dark.
That would be Quiet BOOT mode
kelkel1
2019/12/30 06:19:50
Shortly after posting my previous comment, I had a series of events that had my PC beeping 4 or 5 times and getting stuck on b2. After resetting the BIOS, it went back to normal, but this has happened several times now, apparently at random. Looking through the BIOS, I did not see a 'Quiet BOOT' option.
post edited by kelkel1 - 2019/12/30 06:23:10
snake_solid
2020/01/07 12:36:40
That's odd, usually this option should be in the bios of motherboards having a speaker... my model has one and since 3 months i've desactivated this option...
EVGA Z390 FTW | 9600K 5.0GHZ 1,25v (auto) | 4x4GB BALLISTIX ELITE 3200 CL16 XMP 1,35v @ 4133 CL19 1,35v | EVGA GTX 1060 6GB SUPERCLOCKED |
kelkel1
2020/01/08 17:14:23
The Dark has a Speaker Beep ON/OFF, but that merely enables/disables all beeps. I have it turned ON. Since I usually, but not always, get one short beep, I would not consider what I have as Quiet Mode.
